Hsivany wrote:Scott, how do you handle a wake from a passing boat or some storm-driven waves?
The plane slides up the ramp so that it is about 3-4” higher than it would be if it were floating. This is a huge amount of displacement and the plane firmly sits on the ramp with just about any wave size I experience at lake hood. My slip is right on the east west water lane and I get a lot of wake action from passing planes. The largest of wakes might cause the plane to rock tail to nose, but it is simply rocking along the keel. The only time I have noticed this was in combination with a rise in water level.
Does your plane get pushed up the ramp further?
No. Occasionally the water level will rise due to rain and the plane will float and I have to re-tie, but this is predictable.
If so, do you have to regularly re-tie it? Only after days of heavy rain and the water level changes.
My concern is the plane getting pushed up the ramp by some waves, making the lines loose, then the wind rotating the plane around the loose lines.
I tie the plane to my dock in 4 locations. Bow Cleat, forward rigging, aft rigging, and aft cleat. I am able to aim and slide up the ramp within 3-6” of the fenders on my dock so if the plane floats, it is just like as if it were tied to a dock and floating with slightly loose ropes. No big issue.. I have couple fenders tied to the dock between the dock and the floats and it is a non issue. My dock sits on the bottom of the lake.
Contrary to MTV’s suggestion, I park my plane with the nose towards shore. I do this for a few reasons.
1. I am nosed into prevailing strong winds.
2. If I tail in, my tail hangs over the shoreline and the kids that cut the grass near my plane have to climbed under the tail with their weed hackers and lawn mowers. That scares me.
3. I prefer to have the weight of the plane sitting on more of the keel..
4. I usually depart my dock full and this gives me the opportunity to load a float compartment, spin the plane heel up and load the other float, and depart.
5. When I refuel, the hose reaches the plane easier when nosed in.
Hope this helps. I love my ramp.. it works way better than I ever thought it would.
mtv wrote:As you say, a ramp is pure magic compared to a dock operationally. And, a ramp in the middle of a U shaped dock is near perfection.
albravo wrote:Spent the weekend with a good buddy, felling trees and moving rocks. I think it turned out pretty good but I won't know for sure until I get up there with the plane. Ended up sinking it by building a crib out of a broken ladder, attaching it to the outboard end, and stacking some rock in the crib.
pipeliner wrote:Lots of good suggestions on this old post for building a ramp. It looks like the OP's ramp turned out great. One suggestion that I didn't see is that a lot of docks or ramps can be very easily built on the ice in the spring and then they're in place when the ice goes out. The ice gives a nice, level platform to work from and the weather can be quite nice in the spring while the ice still provides a great platform to work on.
