In a supercub that I installed a G5 in I had to use a magnetometer to make it legal for night. That's just because in Canada we require a DG for night flight so the G5 replaced that. But for the artificial horizon in my 206 I'm not planning to put a magnoneter in.BirdyinBOI wrote:Say...you guys that are using one G5 for not more than VFR flight, are you also installing the GMU 11 magnometer?
dogpilot wrote:This is in the 63-76 manual, do not have the older one:
2-6. LEVELING. Corresponding points on both upper door sills may be used to level the aircraft
laterally. Reference point for leveling the aircraft longitudinally is the top of the tailcone between the rear window and vertical fin.
BirdyinBOI wrote:Jim Hayton at North Sound Aviation says it's the floor. He said the lateral level point is the spar above the panel.
