I am considering a camshaft lubrication modification for my IO-540, and wanted some opinions.
The mod involves drilling small oil galleries in the cam lobes, plus a few other tweaks. This makes pressurised oil flow from the main gallery down the centre of the camshaft and onto the surface of the cam lobes. They receive a fresh supply of cooled, filtered oil under pressure. It's an STC held by Aviation Power Supply but our engine is uncertified anyway. Apparently they have modified over 400 engines in NZ and Australia and never had a problem, almost every model of Lycoming is eligible.
Obviously, a standard Lycoming engine relies on splash lubrication, which is less consistent, takes longer to take full effect during a start, and comes from the hotter / dirtier unfiltered oil supply in the sump. Corrosion of the Lycoming camshaft is considered one of the few Achilles heels of this engine design, given the top mounted cam. The mod only costs about $380 US. This shop has my camshaft out of the engine anyways, so it's the best time for it.
So that's the sales pitch. Any thoughts?
