Was out practicing a few canyon turns in the canyon
I like this technique but it works best if you have a little reserve airspeed
http://www.youtube.com/watch?v=vJc1nD9qyuY
aktahoe1 wrote:Honestly, I think Blu nailed it just watching a few times. Looked like the classic combo of wing over and steep turn. He maintained airspeed for best angle of climb and at the apex of the turn you could hear the horn bump and made a 180 degree turn at the steepest bank without loosing much altitude. I have always thought and will use that as the best procedure. I also dont think this turn was more than 60 degrees either which in my mind is perfect. Adding more bank to the turn, well we know where that could end up...![]()
Ideally if you find yourself in that situation for real, you have some power left in your machine to apply (also a couple notches of flaps) raise the noise while performing a steep turn (not as much bank as a true steep turn, about half) at the apex you may hear the horn bump, continue the turn as the noise drops slightly back to where you started from. You have then performed a perfect canyon turn.
No need for slowing down, adding flaps and trying to stay level while you find yourself in an almost near panic as the walls start to close in on you. Thats a classic spin formula. Having just completed the second branch of spin training that is how we get into them in the first place.
The "slight" steep turn / "almost" wing over formula works very well. Practice the the slow level turn and the other described here and compare the two. I promise you that the one explained is going to turn you around quicker and safer without loosing altitude.
Just my 2c
AKT
littlewheelinback wrote:I'm going to +1 with Gump, the voice of experience. The turn in the video is done with lots of surplus kinetic energy and power...not your typical canyon turn situation.
exodus wrote:If you let yourself to brain fart and get anywhere near a situation such as , narrow canyon, and for what ever reason Not recognized early that things are looking to go to shit and you let your AIRCRAFT SLOW DOWN NEAR Vs, you have no business being in the mountains in the first place. I bet you that most seasoned bush pilots on this forum, may have only ever got themselves into that predicament once in their early days. It's one situation you will not live long enough to repeat often.
