albravo wrote:Love these videos. Looks a lot like home.
If you brought your bike you'll have to make a trip up to Squamish.
A question from a student/wannabe mountain pilot: How do you get comfortable that you aren't going to encounter a strong downdraft when you are in one of those valleys? I'm reading Sparky Imeson's book on mountain flying right now and one of his commandments (that I'm sure he doesn't always follow) is one should always have an escape path, a way to reverse direction in a descending turn.
I may be underestimating the ability of a 182 to turn sharply, but it looks as though the only way out of those valleys is up.
Allan
Couple of comments:
First, when it's windy, don't go there. My personal rule is if the winds at the peaks are more than 20 knots, I don't go into the mountains. Assuming that there's not a major weather system moving through, winds in the morning and in the evening are often markedly less than during mid-day.
Second, Sparky's book is full of wonderful advice, and he was a heckuva mountain pilot. But he died not following his own advice--he didn't leave himself an "out". In fact, a couple of years before he died, he and one of his students crashed because they got too close to terra firma in a descending turn. So having enough altitude to make that descending turn, if that is what is required, is essential.
Often enough, though, a descending turn isn't necessary--a level turn will work just as well, unless the canyon is too narrow, where a descending turn is king. But at a slow enough airspeed, an airplane can be turned on a dime. Canyon turns don't require any pseudo-aerobatic maneuvers; just slowing down and a moderate bank will do the trick most of the time. Fly as near to the downwind side as possible, turn into the wind at 70 knots, perhaps with 10 flaps to increase lift, bank to 30 degrees, and a 172 or 182 or 170 or 180-5 will make a remarkably tight turn with no danger of stalling.
Like anything else in aviation, practice in a non-threatening environment before it's necessary to use any new skill, or any skill that has atrophied. For instance, I will practice level canyon turns over flat farmland, when I haven't done any for awhile. I will practice short field landings and spot landings on runways that give me adequate overruns, if I haven't done short field landings for real for awhile. I will practice low ground effect soft field take offs, if I haven't done that for awhile. And if you haven't done any of that, learn from a competent instructor first.
