CenterHillAg wrote:Lube the cable, make sure the cable is attached tight to the tach and engine, and check for any tight bends or movement in attach points in the run of the cable. All can contribute to the rpm bouncing, but it could still be the internals of the tach wearing out.
I know you said you don’t like them, but installing a Horizon digital tach has been one of the best upgrades I’ve done. Compared to buying a new tach and cable, the Horizon was around $200 more, but far more accurate. Installation was 2 hrs tops.
This ^^^^
My OEM tach failed 2 1/2 years ago, on the way home from OSH. It was not the cable, although its initial indications of bouncing were like a sticking cable. It was the tach itself. On my IA's advice, rather than get a new mechanical tach, he replaced it with a Horizon. At first I was disappointed--its view angle was such that it was hard to read. I removed it myself, sent it to Horizon, and they substituted an angled bezel, which solved the problem--at no charge. I also acquired greater respect for anyone working under a panel, as my hands looked like I'd been in a cat fight after removing the tach. It was a bit easier to install, so I left less DNA here and there that time.
The nicer things about the Horizon, besides dead on accuracy, are its additional features, which allow knowing better how much mag drop there is, when a mag is failing, etc. Its indicator lights also indicate when there's an overspeed (which I usually get by a few rpm on take off) and help set the rpm for run-up. Although it's a couple hundred more than a new mechanical tach, it's so much better than a mechanical tach that I would never advise trouble-shooting a tach that appears to be failing. Best to just yank it and replace it with a Horizon.
