Backcountry Pilot • Cessna 172 Gross Weight Increases, or lack thereof?
27 postsPage 2 of 21, 2
Re: Cessna 172 Gross Weight Increases, or lack thereof?
The field level contingent seem to often not know their own rules, they tend to interpret to suit their opinion. So when present with the formal regulation will usually bow out if confronted by a little bit of push back.
I can't address the regulatory issues of STCs and the like, but I can address the performance issues of loading a 172 variant (whether on the 172 TC or the 175 TC) to gross weight, because I've done it with a lot of different years, versions, and modified aircraft. The highest powered 172 variant I've flown had the STC'd 210 hp Continental, which in reality just allows the governor to be adjusted to permit a higher rpm. The lowest is, of course, the 145 hp Continental. In between, I've flown several 180 hp versions, including a Cutlass RG, in which I probably have 45-50 hours. The most common power increase is the 180 hp Lycoming, both with a fixed pitch and with a constant speed prop. My own is a P172D, on the 175 TC, with a 180 hp Lycoming and CS prop, which I've been flying for nearly 15 years and about 850+ hours.
Here's what I know, from flying all of these 172 variants. They are all pretty much dogs at or close to gross weight--and that's at their legal gross weights. Sure, the higher powered versions climb better and get off the ground a little quicker, and they're able to climb to a higher altitude. But those are only incremental improvements, and their flying characteristics are much less pleasant, than if they're flown at as little as 75-100 lbs under gross. To me, most 172s are really pleasant to fly, under gross and with the CG mostly centered. Load them to gross and at an aft CG (within the envelope, though), and they become twitchy, almost too light on the controls, and much less responsive to control inputs.
I'm not going to admit to flying any 172 (or any other airplane) over gross, although it might have happened at sometime in the distant past (and certainly long enough ago that any statute of limitations has run :D ), but I've flown my own and many others near gross, most out of high elevation airports. Adding an additional 200 lbs, for example, would cause performance to suffer so much that the airplane would have really marginal capabilities. IMHO, it would go from being pretty close to the safest airplane flying to a marginally safe airplane, perhaps even unsafe under some conditions.
To me, the very best way to obtain a gross weight capability of 2750 lbs. is to move to a 182. A 182 flown at that weight is a really good performer, stable, solid, and capable.
Don’t the 180 and 170B have the same wing?
CamTom12 wrote:Don’t the 180 and 170B have the same wing?
170, 172 and 175s have the same wing (mostly) with the early 172s.
180 wings will mount up to a 170,172 or 175 fuselage but the wings themselves are different.
Bagarre offline
Cary's 172 evaluations are spot on, in my opinion. On mountains pipelines having 180 or even 160hp helped a bit, but generally not worth the extra fuel and muscle. They fly great when reasonably loaded and like pigs when heavy and/or high.
Ah, thanks!
My first crop duster was a C172 in about 1975. 150 thundering horses. We stripped the interior and installed tank and booms. It still had two front seats to carry loader when moving. I think it held 60 Canadian gallons. I sprayed with 10 degree flaps and full throttle. It was a bit of a pig for the first part of the load but when half empty I felt like I was running a 600 hp thrush. It got on and off a lot of country roads. To make everything legal it had a RESTRICTED sticker put on. I was to new to know whether it flew well or not but sure was exciting for a young guy.
dogone offline
Aircraft: c 170
