Backcountry Pilot • Cessna 180 Tail Saddle Tube
13 postsPage 1 of 1
I want to replace the tail spring/saddle assembly with a new one from Airframes Alaska, however, the saddle tube is being a bugger. No obvious bends, but a little corrosion visible inside the tube. Clevis pins out, Kroil oil, propane torch, brass drift punch, same diameter socket/extension with 1.5# hammer, pound pound pound, no joy. About all I have left is a cutoff wheel on both sides of the spring, but not a lot of room to work there and it's steel to boot. Any other ideas? Thanks!
jrc111 offline
Re: Cessna 180 Tail Saddle Tube
I read an article of all that stuff and they said the best was a 50/50 mix of ATF and acetone. I tried it and it worked way better than any of the commercial stuff.
KenW
175 magnum offline
Try Mouse Milk.
Its not very oily but it penetrates really well.
TangoFox offline
Keep the Greasy side down!
No luck with 50:50 Acetone:ATF; Mouse Milk next.
jrc111 offline
If you are willing to destroy the inter tube you may be able to slit the inter tube in 3 places with a hacksaw blade and then peel the sections out.
Just a suggestion. Personally, I chose to machined a tool which acts as a punch and a socket with a through bolt to press the pin out. The punch has a smaller diameter on the end that acts as a guide and keeps it centered and a shoulder which presses against the end of the tube without deforming it. You can apply a lot more force in a more controlled manner this way. It also allows you to maintain the pressure while heating the saddle. Sorry I don't have any photos of the tool and it is up in my hanger. I also used the same tool to press the new pin in without deforming it.
bat443 offline
I used a hacksaw blade. The rubber deal is pretty thick so plenty of room to stay away from the casting riveted to the tail section. Took some time but I got it with out hurting anything important.
Mouse Milk no go; I'm fearful of splitting the tube longitudinally because of potential damage to the castings. There's only a 1/4 inch or so between the front of the tube and the bulkhead, so that must of took a while with hacksaw blades! I have a 4inch cut off tool - I'll see if t can cut across the rubber tomorrow. Thanks.
jrc111 offline
Give the mouse milk some time like a day.
Glidergeek offline
Aircraft: 1968 P206C
DG 400
I have had to hack saw several ones out over the years on ones that were bent. No other way to get them out in that case. I have had a few that were just rusted in and took a lot of effort to get them out.
I would try to brace the opposite side of the tail up against something solid like a truck bumper with the proper protection of the skin and paint. You will probably have to get creative.Then I would use a bearing driver of just the right size to pound it out and resort to a air hammer for extra measure.
Without bracing the other side a lot of energy is lost when you are pounding on the tube.
SkyLarkin offline
Mouse milk didn't work after waiting overnight. I couldn't figure out a safe way to use power to cut the saddle tube, so I ended up using a hacksaw. Three hours of moving about 1/4" in and out. Tap Magic, a tool lube, helped. After the tail spring was removed, I still couldn't pound out the tube. The rubber bushing at the tip of the spring was also difficult; I ended up hacksawing it up to, but not through the metal, and forced a screwdriver in between it the tube it rests in, and after an hour or so, got it out. I cleaned up the bulkhead and inspected it; no cracks, applied primer. Getting the new rubber bushings in was difficult; apparently some installations require metal washers (supplied), but I could barely get the rubber in by itself. The saddle tube was also hard; I ended up having to place another jack at the next bulkhead so there was less pressure on the casting alignment. Finally got it done.
Here's some pictures:
1. New tail spring.
https://www.flickr.com/photos/129286532 ... ed-public/
2. Starting to cut.
3. Removed tail spring.
4. Cleaned up bulkhead.
5. Installed.
Next, I want to change out the innards of my Scott 3400 tailwheel, and put it on a baby Bushwheel fork. The baby Bushwheel 3200 I had before is different than this; the bearing is on top - is that bearing pressed on, and will I need a puller to disassemble the unit?
Anybody know of a manual for this? The Cessna service manual is not helpful. Thanks for all of your help!
jrc111 offline
jrc111 wrote:Next, I want to change out the innards of my Scott 3400 tailwheel, and put it on a baby Bushwheel fork. The baby Bushwheel 3200 I had before is different than this; the bearing is on top - is that bearing pressed on, and will I need a puller to disassemble the unit?
Just went through this, but with a stock fork.
The top bearing is indeed pressed on, but it's easy to get off. There are two holes on the bottom of the fork. Use a drift (1/8" maybe?), and alternate tapping through both holes. The drift will be pressing directly on the inner race of the bearing, and it will eventually come off the shaft.
You might need a press to put the bearing back on. My old bearing was in good shape, so I reused it, and I could 'just' press it on with a big socket by hand. The new bearing was tight enough that it would have required a press.
If you can, find a copy of the MAF Scott 3400 overhaul manual. It was very easy to follow and is better than the Cessna manual, from what I've been told. You will need a digital pull scale of some sort if you use the MAF manual.
You will probably have the top bearing on and off a few times as you adjust the shims, but it is well worth the effort to get right.
I need to take mine apart again, as the steering arm is in bad shape internally. Unfortunately, it's the one part I didn't order because it's the most expensive part in the stack by far.
Cannon offline
Aircraft: C-185
Piper J3C-65
Pitts S1S
Good info, thanks ! Ron
jrc111 offline
Here's a drawing for the XP Mods 3400 series t/w. A Bushwheel catalog I have also has a good exploded drawing of the 3400 series, it might be available on the Airframes Alaska website?
13 postsPage 1 of 1
