AK-HUNT wrote:Monarchs or flint tips.
Monarchs way cheaper.
Probably lots of info online re monarchs. Plenty of local Cessna guys have done them. Can get a handle on install prices with a couple calls. It's not cheap.
No not as easy as putting in big bladders. The wing is built different.
Good luck. Buying one with long range wings is the easiest solution
Alaskabound wrote:Im going through this now with my 59' B model. The best option I have found seems to be the solution monarch is offering. They modify your existing bladder (or sell you new ones) and add additional nipples on the outboard side. Then you get a pair of 18 gallon plastic tanks to put in the next bay and they plumb directly into your bladder. Ultimately you end up with an additional 18 gallons per side with no extra pumps or valves. All in I believe it was around $5500-$6000 for everything including new bladders. I plan on getting this ordered in the next few weeks.
Mudwagon wrote:I installed Monarch Aux and Mains about 17 years ago. My 180J had std tanks that made after hours round-trips difficult. (there were not as many self serve pumps back then). I have 97 gal. now and the ability to buy cheap gas and tanker it has paid for the Monrachs several times. I tried to buy a set of 84 gal wings from salvage but they were much more expensive than the mod at the time.
That being said I would probably go with the Flints. The install is much easier. The Monarch aux tank install is major wing surgery.
roamak wrote:Mudwagon wrote:I installed Monarch Aux and Mains about 17 years ago. My 180J had std tanks that made after hours round-trips difficult. (there were not as many self serve pumps back then). I have 97 gal. now and the ability to buy cheap gas and tanker it has paid for the Monrachs several times. I tried to buy a set of 84 gal wings from salvage but they were much more expensive than the mod at the time.
Do you remember off hand what the total weight of the Aux tanks were? The flints are around 20 or so I think right?
Mudwagon wrote:The Monarch mains are 35# less 13# bladder removal = +22# for both and hold 61gal total.
Aux tanks are 24.7# for both and hold 36.2g total. No need for pumps.
If you can do the work yourself it may be worth it but otherwise it's gonna be $$$$.
The drawings and instructions were marginal and the IA and I were on the phone to the guy at Monarch a lot. Of course the second wing took less than half as long as the first which means if you're not doing it or your shop hasn't done a few, you're paying for a lot of staring at parts and drawings and head scratching.
It's great to have 7+ hours of fuel though!
Cary wrote:Now if I just had a 7 hour bladder!
