I was just gonna let this post sit there as another mildly misinformed example of Cirrus-bashing that
used to be common on Beechtalk and POA forums. (They don't do that so much lately.) But then, the successful Cirrus chute pull in Texas yesterday after an engine out shortly after take off over a densely developed area, juxtaposed with the awful Bonanza triple family fatality last week has inspired me to write responses to a few of Cary's comments.
Cary wrote: it has to be repacked to the tune of about $11K every few years--I'm thinking 10, but not sure of that.
You are correct sir. Ten years for the Cirrus BRS installation. Cost may be a bit higher than that, depending on who does it.
Cary wrote:I firmly believe that many pilots of dubious skill would be tempted to use the BRS unnecessarily--and that has been proven.
Well, here you start out expressing an opinion (your firm belief), and we're all entitled to our own opinions. But then you sorta try to turn it into a fact (the "and that has been proven" part), and we're not all entitled to our own facts.
The 2006 pull by a passenger in Jamaica is the only one I know of that may have been, to use your word, "unnecesary'. Let's say "questionable" at least. And that wasn't even by the pilot, dubious or not.
The fact is we (the Cirrrus pilot community) have had the opposite problem. For the first ten to twelve years since the introduction of the Cirrus SR20 then SR22, every year there were fatalities under circumstances where a chute pull likely would have saved the day. Since the pilots were dead, we couldn't interview them to find out if they just forgot it was there, or if the "law of primacy" (stuff you learn first is what you do in a pinch) took over and they focused on what they learned as PPL students (pitch for best glide, pick a place, etc.)
Through the tireless efforts primarily of one man (the tall, bespectacled, pilot with a PhD and a background in how we learn, named Rick Beach) our culture changed, and we gave up the macho BS, and started re-wiring our brains to include "Consider CAPS" early in the tightly compressed decision-making process one faces in an airborne emergency. It took years, and the charts I posted earlier in this thread attest to the results.
My personal case is a bit unusual for a Cirrus driver, and involves this great BCP forum and community. A couple of things caused me to take a different turn. One, I used to hangar my Cirrus part time in Truckee, across from and two doors down from Kevin Quinn. The other was getting my seaplane rating, then buying a Kitfox with amphib floats, getting my tailwheel endorsement, doing a two day spin and upset recovery training, then buying and flying and spinning and just plain having fun in an old taildragger for over a hundred hours, attending the HSF, and eventually converting my beloved 300 HP STOL 182 amphib onto 29" ABW's and adding a third STOL mod (it already had the Sportsman cuff and the Wing-X extensions. I added VG's).
I thought that as I learned more about and became more proficient in off-airport landings, that I'd become less likely to have to pull the chute in the event of an engine failure. Guess what? The opposite happened! Now that I know more about what it takes to make a reasonably well-assessed off field landing, there's no way I'm going to voluntarily glide a small-tired, low wing Cirrus with a 70 mph stall speed down to a spot I have never seen, not have a chance to make several low passes and maybe even roll (or "drag" as a recent thread discussed) wheels on, and have the option to power up and go around. Not if I have another option that has been demonstrated to save my bacon 99% of the time.
Cary wrote:I also believe that some pilots have taken chances that they would not have taken without the BRS.
Yes, we do. We've discussed this to death on the COPA forum. The fancy name is "risk homeostasis". Simply put, as stuff gets better, more robust, and generally safer, we push the activity. As highways got wider and smoother, and cars got better tires and brakes and airbags and such, we drove faster (my Dad remembered that going "forty-forty five" was being quite a daredevil in an old Dodge!)
No question that I undertook missions in my Cirrus that I would not undertake in my 1964 Cessna. And likewise I did flights in my Cessna that I wouldn't try in my Kitfox. And the chute was only one component of the Cirrus equipment package that allowed me to do long cross country trips all over this continent, day and night, and stay within my personal risk profile (which is fairly conservative). I and many Cirrus drivers fly missions that we otherwise would require a light twin to do, and statistics show that we do them more safely than the light twin community. For instance, if it wasn't for the chute and the rest of the equipment package, I would not have made two humanitarian relief flights to Haiti after the earthquake. With PFD's and a raft, I felt comfortable.
When you, Cary, choose to use the phrase "taken chances", it puts an automatically negative connotation on the whole concept of aviation mission profile and risk management. Let's face it, the flying represented on this forum is overall much riskier than the comparatively "dull" point A to point B transportation to and from big, paved, often towered airports that Cirrus drivers typically do.
Cary wrote: But I also think it has actually saved some folks who would have otherwise died.
No question there. I've met a few of them. One is a good friend. He and his daughter will tell you that there is one statistic that trumps the others. Either you live or you die. It is binary. If you die, you are 100% dead. Doesn't matter that they'll say nice things at your funeral and rave about how you died with your boots on, trying to dead-stick in and saving that expensive chute for another day.
In this discussion, only one group of people actually puts their money on the line. That is the aviation insurance underwriters. Two interesting points to consider. One, for comparable pilots and hull values, the rates are lower for a chute-equipped Cirrus than for a light twin. Two, a growing number of them will waive the deductible if you pull the chute. They want you to pull. Not because they are sweethearts but because they employ actuaries to whom only data matters and the data informs them that the chute saves lives and they know that the cost to repair or replace a plane after a chute deployment is nothing compared to the cost of litigation and settlements from fatalities.
Cary wrote: Who knows if all of them were actual "saves", or whether the occupants could have been "saved" through more skillful flying?
My buddy Dick McGlaughlin would tell you that it sure as hell is a "save". As to whether or not he and his daughter might possibly have been saved by other courses of action, he'll tell you he doesn't give a rat's ass. Heck, I know a guy who tried to commit suicide by swallowing what he thought was a lethal dose of sleeping pills while at 16,500' in his airplane. He woke up in a hospital, divorced his pretty but evil wife, got treatment for depression, and started a new life in another state. We can be "saved" from death in an airplane crash in several ways. In each case, I'll choose the one with the highest odds.
As far as being "skillful". Dick has given a few talks and you learn early on that he is a humble man and that an engine failure over the ocean beyond glide range of land goes a long way to reinforcing humility. He's a CFII with a few thousand hours and besides his Cirrus has built and flies a Glastar Sportsman both on floats and in tailwheel config for fun. Yet he calls himself a "below average" pilot. When asked why, he likes to point out that whenever pilots are surveyed and asked if they consider themselves to be of average, below average, or above average skill, the humble say average, and most of us say above average. You don't have to major in statistics to know that half of us think we're better than we are! And in a tough emergency situation, Dick says that we get worse, not better.
Cary wrote:Meanwhile, the marketing goes on, and it's certainly persuasive. Just listen to their ads on AOPA Live every week.
Yep, it is, and thank God! Cirrus is the only company selling a significant number of new, small certified GA planes today, more than the next three brands put together. And of course the experimental business is doing OK. If it wasn't for them, GA would be declining a lot faster than it already is. And before you say you think that's not a bad thing, realize that the entire GA infrastructure of airports, Avgas, mechanics, etc., depends on a thriving small GA industry. We on this forum get to have fun in our fifty or sixty year old Skywagons, experimentals, and such, due in part to the infrastructure that in turn depends on a lively (if not thriving) GA economy. I've met the Klapmeier brothers and I think their induction into the Hall of Fame is well-deserved. After surviving a mid-air collision (the other guy didn't) Alan and his brother Dale set out to change GA for the better, and they did.
PR
