Mapleflt wrote:A quick question if I may that I don't see discussed within this thread. Does anyone use a battery heater, blanket type or other sort ? A warm battery has significantly more cranking power that a stone cold one. In my younger days at latitudes much farther north than I am now we regularly took the battery(s) into a warm space at night or on an extended stay at an out station.
Mark Y. wrote:Sorry, but I just have to ask why?? Why would you keep attempting cold starts over multiple days? Did you test your blockheater? Buy a cheap genset? Engine cover? Yes, these engine will start in the cold with proper technique, but being the single most expensive part on the plane - why not baby it? I know I sure want (Well more like NEED) to get every hr possible out of mine before I have to overhaul. I preheat at anything below 50/55. Maybe even higher. Overkill? Maybe, maybe not, but I think it's worth it.
Nushi wrote:Mark Y. wrote:Sorry, but I just have to ask why?? Why would you keep attempting cold starts over multiple days? Did you test your blockheater? Buy a cheap genset? Engine cover? Yes, these engine will start in the cold with proper technique, but being the single most expensive part on the plane - why not baby it? I know I sure want (Well more like NEED) to get every hr possible out of mine before I have to overhaul. I preheat at anything below 50/55. Maybe even higher. Overkill? Maybe, maybe not, but I think it's worth it.
Mark, ask away. As you can probably surmise, much of this is new to me as a pilot and airplane owner. I'm still figuring out all these little tricks, tips, rules of thumb, etc for this airplane, and in general. There are a lot of things I realize I don't know hence why I'm asking some fairly basic questions. I appreciate the feedback, even if its to say I'm a dumb-ass for trying the same thing twice to expect a different result. Haha. I have thick skin and appreciate that. In the end, acknowledging my mistakes will make me a better pilot and steward of the aircraft. Nonetheless, I did test the block heater, it works, so I will be using it going forward......Lesson learned, hopefully no damage done in the process.
MTV - The airplane come out of annual in November, they adjusted the mag timing at that point, but I'll have my shop look into it again to make sure there's not an underlying issue. Thanks for everyone's comments.
