mtv wrote:What Brian said, he's 100 % right.
That said, some folks really like the challenge, and to have an airplane that is exactly what THEY want. So, contrary to what Brian says, an engine conversion may or may not fit someone's idea of "The right thing to do".
BUT, this isn't just an engine conversion...it's converting a Cessna 150 to tailwheel AND an engine conversion. Both those are extremely expensive processes.
The worst part of this proposal, however, is that at the end of the day, once both conversions are done, you'll have an airplane with very little legal useful load. I've known a couple of people who had these converted airplanes, and neither was legal with full fuel and two "standard" people.
So, you could fly the thing around by yourself, you could fly with minimal gas (and bear in mind the O-320 uses a fair bit more gas per hour than an O-200), or you could just ignore the regulations regarding loading.
Here's what I'd do in your shoes: Find a decent Cessna 170B, and buy it. Fly it till the engine is due for overhaul, and take the huge amount of money you would have spent on the tailwheel and engine conversion on that 150, and convert that 170 to a bigger engine. An O-360, a Continental IO-360 or even a Franklin.
You'll have a good back country airplane that was originally built and designed to be a tailwheel plane, and with a big engine, you'll also have a plane that has some significant value, compared to the 150/150, which is not going to have much value on the market.
Find a good 170. You won't regret it, and you'll be able to take your friend or friends places, and explore.
Not to beat a dead horse but MTV’s added comments are spot on…
We have done two of these over the years.. the first one was a 150 Aerobat… He flew that airplane over gross all the time… second one was a 150 that already had the engine conversion… was owned by the 150-152 type club owner…
If you must have the 150… the most economically way to convert to tail wheel is to have one that already has the engine conversion… That in itself is the #1 most expensive part of it IMO… So, to go along with my first statement to sell your current one and get one already done, you could look for just an 0-320 powered aircraft in your search…
The 170 though is an extremely sought out aircraft.. If you can find one for the right deal don’t hesitate and snatch it… One of my customers just sold his highly modified 0-360 powered 170 for 135K… [emoji15]… They are one of the few airplanes that the value just seems to go up on..
Brian
