DonC wrote:What ever happen to stop drill and wait for annual....good enough for crankcase should work for spinner
Kenmore Beavers had problems with 3 bladed prop spinner backing plate cracking in the old days.
Once upon a time I had a problem with a spinner... one of the nut plates for the screws that hold the spinner to the main backplate got a little bit stripped. It would still hold part way in the stripped nut plate, it just wouldn't tighten all the way down hard before popping one thread backwards. Very wisely, I made a mental note to myself that I would have to replace the nut plate when I got back later. What a smart, wise, brilliant young pilot I was, to think about those tiny details.
So I took off from my home airport (KWHP in the northern part of Los Angeles), and I got precisely seven miles from the airport when I saw a blue flash and heard a gunshot. Immediately the airplane began shaking up and down so hard that my hand came off the stick. For some reason, certainly a miracle of brain processing speed in the mind of such a clever and handsome aviator, I remembered that this airplane was not equipped with a "safety cable" that wrapped around the crankcase and bolted to the firewall/upper longeron connection. (we were required to have those on the race planes, but this airplane was an RV-3 sportplane). It was pretty obvious that in a few seconds the engine could shake itself off of the front of the airplane.
Having just recently been a contest pilot in gliders at that time, I was willing to shut off the mags first and deal with the glider aspect later. So I shut the mags off with one swat (two toggle switches). The rest of the story, the river bed, the pay phone, the Sheriff's Department, the newspaper, the 8 hour disassembly and transporting it all back home at 3 in the morning, is another story.
The point of this rant is only that the spinner has a lot more force on it that you might think, and that a crack, stripped nutplate, or broken fastener... can become a much bigger problem than you want it to be. I know a l ot of you guys have a lot more field experience than I do, but "Stop-drill and keep flying" is definitedly not something I can recommend !
Here's a page from my website that has a (really grainy lo-res scan copy) photo taken by the reporter, bottom right. You have to look closely to see that a good size piece of the propeller blade is missing.
http://www.grantstar.net/index.php/avia ... ories.html
