jmurtap wrote:I pulled the trigger on a set of the 850x6 smoothies for my 170b, Hope to have them on in a couple of days. Does anyone know if I'll have to remove my pants backing plate? I'm hoping they don't interfere and will be able to leave them on, so I can easily switch for showing purposes. (the wife really like's the pants and insist they are worn during XC)
mtv wrote: What are you using for an approval basis? ........
whee wrote:Kinda wish I would have ordered the 10" wheels instead of the 6" wheels with my ABI wheel and brake kit.
Zzz wrote:Hey, it's only money. Pick up a set of 10" wheels now. You'll need your 6" set for running 8.00s on your wheel skis
A1Skinner wrote:I'm curious how much difference there is when it comes to running over obstacles with the 10" wheels vs the 6" ABWs ...
blackrock wrote:A1Skinner wrote:I'm curious how much difference there is when it comes to running over obstacles with the 10" wheels vs the 6" ABWs ...
I don't know, but when the wind stops blowing here, I'm going to go look for the rock I hit in the T3 video. It is easy to see in the slow motion view. I damn sure felt it on 31's at 7psi, but no damage done to the plane. At least not anything obvious. I don't think the rock itself is all that big, but it may have stuck up out of the ground a fair ways. Not sure I'd want to hit anything larger that was solidly anchored like that one may have been. I'll bring it home as a souvenir if I find it.
Maverick never found the one that took out his flying wire, but he sure heard it. a lot of damage is caused by what the tires kick up, not always what they roll over. Remember the concrete slab (I think that is what he determined?) that took out Kevin's elevator a few years back?
A quick measurement on 35's gives 11-inches from the edge of the 10-inch rim to the top of the tire. On 29's with 6-inch wheels, it is also 11-inches. So, on 31's a 10-inch wheel could expected to have about (10-6)/2=2 so 11-2=9" based on the 29's. Or estimating from 35's (35-31)/2=2 so 11-2=9". Looks like about 9-inches of rubber and air for 10-inch wheels vs 11" for 6-inch wheels.
It would just depend on how much air pressure was in the tire; compressing a tire by 9" may give you more to worry about than rim contact, though.
