I have the analog version of the Alpha Systems AOA, which I don't think they offer any longer--it looks like the classic lift reserve indicator, but it functions differently, so I understand. In any event, I like it. It's mounted on the top of the glare shield so that I can see it and the touchdown spot without staring at either one of them. I have flown maybe 500 hours with it, vs. some 2400 hours without one. It took awhile to get accustomed to using it, but as a result of doing so, my approaches and landings have been at markedly slower airspeeds when I'm running light, which is most of the time. Although I agree with motoadve that it's usable in other regimes including take offs, I rarely look at it or the airspeed indicator on take off, even from a relatively short strip.
Since I'm so accustomed to high density altitudes, the idea that Big Bear at 6750' is a particularly high density altitude airport always strikes me as funny. But for "flatlanders", I have to agree, and there are a couple of very specifically important things to consider.
First, the engine must be leaned properly. Frankly, I have no idea how to lean a Rajay equipped Continental. I suspect it is usually run full rich like most turbo-equipped engines, but I don't know that. Without the turbo, it has to be leaned just like any normally aspirated engine, to best power.
Second, as important as proper leaning is, it's just as essential to fly normal airspeeds, which fool some folks because of the visual appearances that result from higher groundspeeds. Approaches will be at higher ground speeds, most noticeable as the airplane gets closer to the runway. Even with turbo-charging, ground rolls will be longer, visual appearances of speed will be greater (because the groundspeed is faster), climb out at the correct airspeed will be at a lower rate of climb, and in the event of a go around from a botched approach, the airplane won't recover nearly as well.
