Backcountry Pilot • Engine is toast turned into full plane project
366 postsPage 10 of 191 ... 7, 8, 9, 10, 11, 12, 13 ... 19
Re: Engine is toast turned into full plane project
hotrod180 wrote:Paul, what's it looking like re completion date?
Eric, the line in the sand is March.
Not only is the screen scrunched up, but several of the wires in the screen are broken off.
can repair these or go with the Burl ones https://www.burlac.com/Fuel_Screen.pdf
corefile offline
Aircraft: Cessna 180 - sold
I installed a Burl's----it is way better and slid in the nipple easier.
Yowsa! $250 each. For me, that would be $1000 for my two tanks.
C180_guy offline
C180_guy wrote:Yowsa! $250 each. For me, that would be $1000 for my two tanks.
I could spend a lot of time practicing my soldering for $1000 USD
No kidding. Beautiful product though. Probably a big chunk of the expense is for the STC. I think one make the argument that this is either no alteration or at worst, a minor alteration. Or, let me chase down a field approval and charge less.
C180_guy offline
Yet another find of mechanic malpractice.
corefile offline
Yeah. You’re going to find stuff like that on these old airplanes. Who knows what the story was there.
Ugly as it is, I think it’s airworthy. The split pins will sheer before you tear out through the middle of that snowman. Never going to lose the hollow shaft out of the saddle due to that.
For those that don’t know, the holes for the split pins are drilled at random locations, angles, and not though the tube centre. They are matched for life and have to go back in the same way they came out in order to get the split pin holes to line up.
Pinecone offline
corefile wrote:Yet another find of mechanic malpractice.
Ah, the Bushliner syndrome is contagious
Pinecone wrote:For those that don’t know, the holes for the split pins are drilled at random locations, angles, and not though the tube centre. They are matched for life and have to go back in the same way they came out in order to get the split pin holes to line up.
Yeah - think should be able to repair, was thinking weld/fill in the non used side of the snowman and then straighten out the wobble on that collar.
corefile offline
I'm pretty happy with how these assist handles came out, handles match my paint scheme and replaced the old handle ends that were about to pull through the screw with these new titanium ends.
corefile offline
corefile wrote:I'm pretty happy with how these assist handles came out, replaced the old handles ends that were about to pull through the screw with these new titanium ends.
Where did you get these? I need a set for my 206.
Edited for terrible spelling...
A1Skinner wrote:Where di yoy get these? I need a set for my 206.
https://www.lostriverparacord.com/ProductDetails.asp?ProductCode=CG800
He is using the picture of mine on his page that he made. If you just want the ends, without the paracord handle, you can get them from bushliner.com
corefile offline
Thanks!
$100 each.
Do you know how much Bushliner gets for just the ends?
Wang leather straps would be a nice, old school touch.
hotrod180 wrote:
$100 each.
They are $25 per end which includes(titanium end, screw, and bushing - they made it so there is a bushing between screw and the titanium end (like how the seatbelts are attached)) - so $50 for each handle for the titanium ends.
corefile offline
looking forward to getting the 180 stripped, primed, and painted.
corefile offline
Another little mechanical issue that was fixed as part of this.
Ah... the old upgrade your generator to a 70 amp alternator - but leave it on a 50 amp circuit breaker install method. And yes I did have that circuit breaker pop before.
Nice, 70 AMP ALTERNATOR, I gots power to spare
Not so nice - they installed it and kept the original 50 amp circuit breaker
corefile offline
Yeah, 50 A breaker (along with under-sized wire) not so good; however, wonder if there will ever be a 50 A load. Wonder how many owners have an up to date situational load analysis/spreadsheet? Probably only a handful. By situational, I mean what is the flight scenario - night/ifr/icing is going to have a higher electrical load than day/vfr. I prepared one for my plane years ago and was good to know I still had some margin even in worst case situation/worst case duty cycles (eg, radio transmitting vs just receiving). And, I am still running incandescent lighting with a 60 A Ford alternator.
C180_guy offline
Looking good!!! Those Quasars are going to be a nice touch, I got them for my 170 with the Sportsman also, well worth it. Also I second the comment about the newer rudder pedals, mine were worn badly and I swapped them, much nicer feel.
That Paint scheme looks awesome, cant wait to see it!
Huminajumina offline
Aircraft: Cessna 170B
corefile wrote: looking forward to getting the 180 stripped, primed, and painted.
Is Bushliner gonna do the painting also?
