corefile wrote:skyward II wrote:corefile wrote:Nushi wrote:
What do you have going on under the PAR200B? That the autopilot? Looks fantastic! Love everything, especially that switch panel.
Yes that will be the Dynon Autopilot - once it’s been certified for the 180 - I have the wiring harness already installed - just the Dynon ap module and servos to install once it’s legal too.
And where are they with this? Any progress?
Beautiful aircraft.
That was back in the day when I had faith that Dynon was going to certify their AP for the 180. They are like 3 years late on the 182, which they had previously committed to years ago, and they are not even doing the early model 182 that have a stabilizer with a jackscrew, as all the 180/185’s have - that told me all I needed, I no longer believe they will ever certify their AP for the 180. I ended up going with the Trutrak Aerocruz as it worked with the rest of my Avionics. Also, I ended up with a different final panel layout as well based on some other decisions along the way.
You must be absolutely chomping at the bit. Congrats! Gorgeous!
Is there an issue with jack screw servo’s and should I assume the Trutrak has no pitch trim servo on the 180?
Give us the number on your new stall IAS, please.
