Engine monitor Harness brackets
I have seen tab brackets that install on a single valve cover bolt that hold the monitor harness in a p clip on quite a few engine monitor installations. Is there a spruce part number for these? Or just fabricated?
Mark Y. offline
440
- Aircraft: Cessna 182B
I usually make them. Then you can adjust the length and both hole sizes as needed.
On The Fly offline
199
- Aircraft: C`182K
