Exhaust gaskets
Going to be putting a new acorn exhaust system in the 182. Are the blow proofs worth the extra money versus the solids? Which ones would you recommed?
Mark Y. offline
440
- Aircraft: Cessna 182B
Mark Y. wrote:Going to be putting a new acorn exhaust system in the 182. Are the blow proofs worth the extra money versus the solids? Which ones would you recommed?
Yes!
TangoFox offline
621
Keep the Greasy side down!
Yes! Even with the “no blows” you need to inspect the exhaust connection often. It’s a real bummer when a leak there is left unchecked.
Halestorm offline
956
- Aircraft: C-182E Pponk
The spiral wounds are definitely worth the extra money Mark.
5186
