Mark Y. wrote:Not sure what the issue is exactly. masked elevator or too much drag. My bet would be on the added drag. I never tried when i had my N model with 40 deg of flaps. I know my flight training always beat it in to me, full throttle and flaps to 20 deg in a go around. Didn't matter if there was 30 or 40 deg out. I would never give up the 40 deg.
Your flight instructor beat that into you
because of the lessons learned by people before you.
If you've got 40 degrees hanging out and are trimmed hands off, and firewall the engine you will have your hands full - no kidding.
If you're prepared you can firewall it and set flaps 20 immediately (exactly as you were taught) and pin the cowl on the horizon until you see positive rate of climb, etc.
You'll be pushing very hard on the yoke until you've got that 20 degrees selected at which point you can reach the trim wheel and get some relief.
Just wait until you're mushing along in a simulated go around and your student slaps the flap lever into the UP position. She commented later that she had never seen my hand move that fast.
