mtv wrote:We replaced these bricks with Odyssey batteries, lost 8 pounds and gained almost total reliability.
How the the Odyssey's stand up to the sometimes extended cranking of a fuel injected engine in the summer?
Did a 185 on wheel ski's one time!!
Felt real good when it finally started!!
I'll try never to do that in the future!!
Littlecub wrote:^^^^ Hand propping a little Cub on skis in snow is like on floats. No big deal. From behind and feet apart and as stable as possible, and with a good grip on the door frame with the left hand, use the right hand to toss the prop.
Sounds a little precarious, but what IS precarious is on bare ice. Real good grip with the left hand. And feet as stable as possible (boards, boughs, grass, sand-or just good boots).
Be careful/pay attention-and don't let it become "routine"......
Barnstormer wrote:mtv wrote:We replaced these bricks with Odyssey batteries, lost 8 pounds and gained almost total reliability.
whee wrote:Your supposed to dress warm but what do you guys wear for your outer layer? I usually wear insulated carhartt overalls and a carhartt coat but if I get stuck out overnight and get wet then they will be good for nothing. I don't want to wear my MotorFist snowmobile gear because in a fire it will just melt.
Beamerpilot wrote:As for hand propping, daily occurrence I carried a “snow hook” in the baggage compartment (used on a rope behind dog sleds to hold it parked while the dogs keep the tension on) attached to a length of rope on the tail wheel and anchored it in the snow or dug it into the ice with the axe. Why so much trouble...the pilot I replaced was fired due to his PA18 disappearing in the distance...to eventually roll up in a ball a couple of miles away.
..... ski flying, in my experience, offers by far the greatest diversity of challenges of any type of flying.
M6RV6 wrote:Littlecub wrote:^^^^ Hand propping a little Cub on skis in snow is like on floats. No big deal. From behind and feet apart and as stable as possible, and with a good grip on the door frame with the left hand, use the right hand to toss the prop.
