Backcountry Pilot • Flying to beaches
Flying to beaches
4 posts • Page 1 of 1
Flying to beaches
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: Flying to beaches
There are soooo many variables while landing on beaches, and people need to be aware before trying this.
Touch and go is a good idea but not a regular plop down, You want to barely touch the mains (not the nose) while carrying power and be able to feel the surface, if it starts to grab you you need to be able to fly out!
Every beach is different, some are hard as concrete, others are hard as concrete sometimes, some are always soft and the only way to land is with cub type airplane with Bushwheels.
The beach will also change with every tide. may be hard one day and soft the next.
You made me cringe with the relaxed elevator, its bad form and your nosewheel can dig in so fast it will make your head spin.
With a nosewheel plane you are also better off loaded aft, even if you need to add ballast to baggage compartment
a 182, or 206 with just a pilot and heavy on the fuel can be bad.
Steeper bank does not mean softer, sometimes lower where it flattens out is the softest place. Like I said every beach is different.
Also its best to land on an out going tide, that way when you get stuck you have more time to dig out before you loose your airplane. :shock:
TangoFox offline
Keep the Greasy side down!
Great photography as usual. Thanks for sharing.
On The Fly offline
Aircraft: C`182K
On a soft field landing might a 20 degree flap setting allow for more elevator (less downwash, higher pitch attitude)? I would agree keeping the yoke full back after landing is correct soft field technique.
A couple of advantages for tail wheel (soft sand will cause a nose over as well) might be: less propeller erosion due to better clearance, and ability to use low psi tundra tyres.
L18C-95 offline
Aircraft: Piper L18C-95
