Backcountry Pilot • Hangar Doors
Hangar Doors
87 postsPage 4 of 51, 2, 3, 4, 5
Re: Hangar Doors
I've read most of the comments on Hanger Door's with keen interest. Sliding doors(Lake Mohave) are the biggest pain but cheapest . Bi-fold doors are great but come at a premium price . We built a 50x12 (AZ50 ranch )bifold with everything for around 2 grand -Steel, motor and drive bar . My other hanger(BVU) has a 70 x14 foot bifold that works pretty good and eats electricity at a demanding rate . If you have a electric door have a generator for back up else get trapped when power goes out. I'd like to try a Hydro swing but have held back by hydro cylinders cost .. Material's cost is driving factor with 2 inch square tube and welding rod +labor . Electric motors and drive units run 2-300 bucks ,sheeting for outside is easy cost. Most of the door company's will run 8-12 grand with there installation. Pole barn (40x40) with roll up fabric door is pretty cheap but dirty .
182 STOL driver offline
Re: Hangar Doors
courierguy wrote:...can I run a 240 motor off 120, using just one of the hot leads? It'd be slower but better then nothing)...
Sorry Tom, nope. But you might get a chance to have a brief look at the magic smoke!
marcusofcotton offline
Re: Hangar Doors
I'm curious as to why it would smoke? Hooking up half voltage, and only one lead? While I don't think it would work, it shouldn't smoke. Now if you were hooking 240 up to a 120 motor it would smoke.
Re: Hangar Doors
The motor torque would drop to a small fraction of rated torque, resulting in the motor running slower (if at all). Slowing the motor even slightly raises current draw significantly, causing heat and burnt insulation if protections aren't in place.
Re: Hangar Doors
Good to know. Thanks Marcus!
Re: Hangar Doors
I have a manual boat crank style door that is similar to the miracle stated previous it is welded out of thinwall 2 inch tubing have about $1800 probably in it it is great can be built with a little bit of effort pretty simple but very effective I can maybe get some pictures if you would like
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
tcraft wrote:I have a manual boat crank style door that is similar to the miracle stated previous it is welded out of thinwall 2 inch tubing have about $1800 probably in it it is great can be built with a little bit of effort pretty simple but very effective I can maybe get some pictures if you would like
Pictures are always good :)
TxKiger offline
Aircraft: 182
Re: Hangar Doors
Crzyivan13 wrote:Im saving my pennies for one of these. It is a freestanding hydraulic door that requires no superstucture attached or built into your building. It's all self contained so a retrofit is easy.
Reminds me of my favorite door. Look in the bottom right corner at the beginning and you'll see me walking into the hangar to give a sense of scale. I'm not a tiny guy...
rw2 offline
Aircraft: Experimental Maule
Re: Hangar Doors
That's impressive, that's one big door and it sure opened fast!
Re: Hangar Doors
courierguy wrote:That's impressive, that's one big door and it sure opened fast!
1930's engineering at its finest.
rw2 offline
Re: Hangar Doors
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
Does my video open for you guys??do not have a computer to check
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
The video view is kinda "squished", plus on at least the second video the imagery is laying on it's side. Better review your techniques and/or cam settings.
Re: Hangar Doors
iPhone glitch noticed that myself did not film it that way Will see what I can do to fix it was just curious as to whether it got uploaded I do think you
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
Rob did you get my message?
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Doors
Has anyone used "Diamond doors" bi-fold doors? I have a quote for $5700 for a 38x12' door shipped to my house with all hardware, motor, etc.
Bender offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... QWUi6dqfEQ
Aircraft: PA-22/20
Re: Hangar Doors
Bender wrote:Has anyone used "Diamond doors" bi-fold doors? I have a quote for $5700 for a 38x12' door shipped to my house with all hardware, motor, etc.
I don't have a hangar but have used 2 different diamond doors on seperate occasions. They worked very well. The locking mechanisms worked great for suckling the door tight. Only thing is I wish they used straps intend of cables.
