Backcountry Pilot • Helmets and Backcountry Flying
65 posts • Page 4 of 4 • 1, 2, 3, 4
Re: Helmets and Backcountry Flying
Dug a little deeper. Here is the new standard out from the DOI/USFS: https://www.doi.gov/sites/doi.gov/files ... rev4.3.pdf
The standard is essentially a DOT standard plus comms.
Also spoke with a colleague who built his business on helmet testing, he is an industry expert. He had very good things to say about the Team Wendy helmet, from his assessment the R&D team knows their materials well and builds a great helmet. He didn't think it would be worth looking for a helmet that meets the DOI/USFS standard because that use case it a little different than ours, and the cost is significantly higher, like $2500+.
hamer offline
aftCG wrote:This subject has been on my mind for a while now, so I finally did something about it.
For those of you who want a back country helmet and you want a good one but don't have a million dollars, here's what I just put together.
This is a Team Wendy Exfil SAR Tactical, with the Peltor adapters.
I've been a user of Peltor headsets for over 25 years. I know they look goofy and cheap but they are hands down the best passive noise reduction headsets ever, and they're more comfortable than almost everything else after a long day of flying.
I didn't want to chop up the matched pair I have in my Citabria so I looked online where you can find them cheap. In my case, eBay for $75. These were white so I ordered the white helmet shell from Team Wendy.
Peltor got out of the aviation business a long time ago apparently but they're still an industry go to supplier for passive noise protection. The black sleeves used for adjusting the head band are not compatible with the older aviation headsets but they slide off and you can use the old ones.
No tools, no butchering of anything but the old head band to get the wire out. I've got a giant head so I didn't even need to use the foam padding kit.
Once these pass a flight test I will be ordering the kit to convert them to ANR. That kit includes new gel seals and mic muff.
I've never been a fan of ANR only headsets, an opinion recently reinforced on a cross country, scud running when the batteries in a set of Bose went dead and I "sort of" wanted to hear.
I am looking into doing a similar setup and finding a used headset to get get started. Is the Peltor you are using a 7004 or 7006? Do you know if the 8003 works with the Sky Cowboy kit?
I think white is the way to go, in the southwest with a big skylight. Should help to keep my brain from melting.
moto657 offline
Aircraft: Piper PA22/20
I’ve been flying with the Team Wendy for about a year with Bose headset...very happy with the set up except the tinted visor...seems to reflect to much light and distort forward viz...if buying again I’d like pass on that option....
Airdave100 offline
Aircraft: 1956 Cessna 182....N5632B
Airdave100 wrote:I’ve been flying with the Team Wendy for about a year with Bose headset...very happy with the set up except the tinted visor...seems to reflect to much light and distort forward viz...if buying again I’d like pass on that option....
Good to know. I've seen some other reviews that mention distortion if you look down through the bottom of the visor. Although the visor looks really cool, it maybe best to pass on it.
If you get the "Backcountry Bundle" which includes the helmet, visor and an inReach mini, you save $50, bringing visor cost down to $50. Do you think it's worth $50?
moto657 offline
Yes...for $50 it is worth adding...if you’re in a bad situation and could remember to lower it the safety for your eyes would be worth it...
Airdave100 offline
