Mister701 wrote:You ought to see it when it gets cold!
Mister701 wrote:I laid awake all night trying to figure out how it got to 69% humidity at 27 below in Fairbanks. It says severe clear with -31 dew point. I recall days like that but the humidity more in the neighborhood of 15% or so. I must be thinking this through too hard. Spring time in Mississippi.
Hey thanks! I should know that but now I do. Very good sir!tcj wrote:Mister701 wrote:I laid awake all night trying to figure out how it got to 69% humidity at 27 below in Fairbanks. It says severe clear with -31 dew point. I recall days like that but the humidity more in the neighborhood of 15% or so. I must be thinking this through too hard. Spring time in Mississippi.
The key word in the Humidty definition is "Relative". It is relative to how much moisture the air can hold at that temperature (-16F). The colder the air the less moisture it can hold. At 69%RH and a temperature of -16F the air is holding very little moisture and that is about average for the low relative humidity of a day in Jan. in Fairbanks.
Now, take that 69% RH air with a -23F Dew Point inside the house and warm it up to say 65 degrees F and the RH will drop to 2%. That's why it is so dry in the house in northern climates in the winter. Think about the carb icing chart. When the temperature is 68F it can hold a lot of moisture to turn to ice in the carb.
Relative Humidity calculator http://www.hpc.ncep.noaa.gov/html/dewrh.shtml
Nosedragger wrote:So, how much manifold pressure can you pull at 6k below sea level? I don't think my carburated 470 would even run, but if it did, I doubt the jetting would accomodate that air. Maybe with carb heat on
denalipilot wrote:Nosedragger wrote:So, how much manifold pressure can you pull at 6k below sea level? I don't think my carburated 470 would even run, but if it did, I doubt the jetting would accomodate that air. Maybe with carb heat on
My old O-300A responded very well to pulling carb heat in those conditions. Smoothed it out considerably and increased RPMs by 50-100, if memory serves.
-DP
175 magnum wrote:So when the DA goes to -5600' do you guys automatically get free lean of peak operation?
Users browsing this forum: No registered users and 32 guests
