Backcountry Pilot • InReach Questions and Plans
74 postsPage 3 of 41, 2, 3, 4
Re: PLB
whee wrote:Can you send a message from one inreach to another? Say I get caught on one side of a pass and my buddy is on the other, no cell service. Is there a way to contact each other if we both have an inreach?
Yes, you can do this.
Prosaria offline
Re: PLB
Yes. You can send msgs to mobile numbers, email address or another InReach device (or all at the same time..think a group text) Your msg is going to a satellite, then on to its destination.....
I've used it extensively in the field on the Enterprise plans and HIGHLY recommend it.
Kaptain_K offline
Re: PLB
Very cool. Thanks guys.
Re: PLB
Good question. That's a good feature to know about.
Re: PLB
Yes, absolutely.
rw2 offline
Aircraft: Experimental Maule
PLB
inReach... inHand! [emoji41]
Quick delivery from MEC.
Sent from my iPhone using Tapatalk ProImage
rodhilton offline
FindMeSpot URL: https://share.delorme.com/RodneyHilton
Aircraft: 1958 Cessna 172
C-FKJJ
Re: PLB
rodhilton wrote:inReach... inHand! [emoji41]
Rod, from what I see on the Canadian website, there is no enterprise plan. Have you found different or which plan do you plan on using?
Re: PLB
There is a 15% discount on all plans through COPA... I was looking at the $34 /month package.
Rod Hilton
Kincardine, Ontario, Canada
C-GNBI
Tapatalk Pro
rodhilton offline
C-FKJJ
Re: PLB
Rod Hilton
C-GNBI
Tapatalk Pro
Good to know. That one would almost be enough for my flying. Based on my yearly average I'd be about 20 hrs worth of flying short though. Need to do more research. So far my spot hasn't let me down and is less then half the price...
David
Hythe, Alberta
Re: PLB
A1Skinner wrote:Rod, from what I see on the Canadian website, there is no enterprise plan. Have you found different or which plan do you plan on using?
enterprise.delorme.com
TradeCraft offline
Re: PLB
Just takes me to a sign in page.
Re: PLB
The title of this thread ...... hmmm
A PLB is just that - a BEACON (like your ELT) whereas an InReach is more of a communications device.
A PLB has an initial cost but no on-going subscription charges.
A SPOT is kind of a half-assed compromise between a PLB and an InReach. It also is not very reliable at high latitudes.
I think we should, in the interest of safety, assume that our ELT will be damaged in a crash of fail to activate for one reason or another. Statistics show that the likelihood of that is actually quite high. So we need a back-up. I choose a PLB in my pocket as primary. Then I figure I need a back-up to the back-up, and an InReach makes a good "beacon" as well as a fun communications device. The Iridium sat-phone is carried because it's the only way I have to close a flight plan from the bush or to hear my wife's voice and convince her that I'm okay. And, when all else fails, I can call up that Japan Airlines 747 overhead after I escape from the burned-out wreckage with my handheld VHF.
Having back-ups to the back-ups is the rule with me. Hence the axe AND the saw.
I also wear a belt AND suspenders!
I know it probably sounds like over-kill, and for most pilots it would be, but I fly in some of the most-remote country in Canada, without another friendly bush-plane for 300-miles, and often not another human being within a hundred miles.
NunavutPA-12 offline
Re: PLB
Just go to their home page. Then look in the column on the left. The third option is enterprise. Click on it and it brings up the enterprise solutions page. Mid page on the right you'll see three links in a blue box. The top link is "Download the Enterprise Sell Sheet". Click it and it will open a PDF with the info on the Enterprise plans.
PLB
Hey Rod,
Given this read has become mostly about the Delorme Inreach, it might be a good idea to modify the thread's title to something like "Delorme Inreach Questions and Plans" or something like that. It might help someone in the future who is looking for info on Delorme.
Let us know how you like it!
Re: PLB
For the Canadians on here, it's located under the working alone section. Here's a link for the enterprise on Canada. http://www.inreachcanada.com/inreach-fo ... ing-alone/
Re: PLB
I came across a deal on an Explorer on ebay yesterday and ordered it. I'm excited.
Also, a friend that has one sent me an email yesterday about a promo they are doing. If you buy from them, you get $50 off plus a $50 credit, and the friend referring you also gets a $50 credit. Offer ends 12/09/16 I think.
Re: PLB
As a side note, when I emailed Spot to cancel, they offered me a $60 loyalty reward if I'd change my mind. Thought I'd pass it along for any spot users out there.
Re: InReach Questions and Plans
Grassstrippilot wrote:Hey Rod,
Advice Taken[emoji41]
Rod Hilton
C-GNBI
Tapatalk Pro
rodhilton offline
C-FKJJ
Grasstrippilot,
What InReach plan did you choose? Sounds like you ran the numbers pretty thoroughly and am interested in what you decided. I purchsed the inReach Explorere but have not activated it yet. Is it fairly straightforward to link it to your smart phone?
I could not find any details on the Enterprise plans. The link mentioned here did not give me the information.
Jan
mjwings offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... ol8EAWGCQe
Jan
mjwings wrote:Grasstrippilot,
Jan
I ended up on the Enterprise plan here in Canada, and applied the COPA discount.
Rod Hilton
C-GNBI
Tapatalk Pro
rodhilton offline
C-FKJJ
