bat443 wrote:I have the STC and seats for my project but it will be a couple of months before I get to that point. There are a couple of "got ya's" with the STC, the first being that the part numbers of the required seat rails are now spelled out so you will need to buy about $1200 of seat rails, and second the seat position on the rail is spelled out in the STC so the seats are no longer adjustable. They are to be installed in the forward (actually only) hole in the rail which puts the front of the seat where the front of the bench seat is. I am going to speculate that this position was chosen so that a supplement to the AFM weight and balance data was not required. I plan to ask for a field approval to drill another hole in the track and specify a different arm in a AFM supplement to move the seats back a few inches.
bat443 wrote: much easier to push around on the ground.
qmdv wrote:Just because i have an inquiring mind, why would you pay 1600 bucks for seat rails, buy 206 seats and then buy the STC. I was thinking of doing that with my 1956 182 but instead went for folding seats STC. Right now the Lakevue jump seats sell for 2300 bucks. Atlee Dodge a bit more. I like the Lakeview cus easier to install and you can unbolt them and install the original rear seat in with no modification.
I have had these seats for four years and have had people in them less than 20 times. More like 10
frstnflt wrote: Sounds like a chunk of change and hassle not including matching upholstery.
kg wrote:…...The blue seats are the Cessna "jump seats" in my airplane. No adjustments. Just a stool with a straight back. The back can be lifted off to allow room for long things in the baggage area and the seats can be removed fairly easily by unscrewing a thumbscrew from the side wall. They can be stowed in the extended baggage compartment. Functional but not comfortable.
hotrod180 wrote:kg wrote:…...The blue seats are the Cessna "jump seats" in my airplane. No adjustments. Just a stool with a straight back. The back can be lifted off to allow room for long things in the baggage area and the seats can be removed fairly easily by unscrewing a thumbscrew from the side wall. They can be stowed in the extended baggage compartment. Functional but not comfortable.
I had a single one of these Cessna jump seats, aka C180/185 middle row seats, in my old C170.
Yep, they're uncomfortable, at least partially because they are too far forward.
I have the BAS (now LakeVue) folding jumpers in my 180, I find them much more comfortable.
Of course, I've never gone for a long ride sitting in them.
IMHO if you really want comfort, install a stock bench seat.
Halestorm wrote:….I do like that the aftermarket jumpseats use brownline track on the floor that can be used for cargo anchors.
