bigrenna wrote:Barnstormer wrote:
Hank, I'm unable to find Aeropod (related to aviation) on the Interweb. Do you by chance have any contact info?
Aeropod is Tony Lopez (BCP member,) but he makes the belly pod. The carbon fiber extended baggage is Todd Hitchcock and made by Airglas.
http://hitchcockaviation.com/detail.php?item=31&cat=Cargo%20Pods
One of the things to keep in mind if you're considering an Emerging Lifesaving Technologies ELT: That ELT is the only one made that does NOT transmit a 121.5 signal in addition to the 406 signal.
Another issue of having a 406 that doesn't have 121.5 is that not all SAR groups have the capability yet of homing onto a 406 signal--they need the 121.5 signal. So it's IMHO it's important to have an ELT with both frequencies. Like everyone else here, I don't ever plan to need my ELT, but if I do, I want it to bring the rescue as soon as possible.AEROPOD wrote:bigrenna wrote:Barnstormer wrote:
Yep, I do sell a mod that you need for your 185. Every 185 should have a belly pod if you truly want to get as much utility as possible out of it. Plus, with that Wing-X kit, you'll need more space to put all that weight. [email protected] should finish up my shameless plug...One of the things to keep in mind if you're considering an Emerging Lifesaving Technologies ELT: That ELT is the only one made that does NOT transmit a 121.5 signal in addition to the 406 signal.
Great point, I know every time I climb through 10K at work I saw #2 over to 121.5, as do most airline types. Every time I hear an ELT, I report it to center. I fly out in the sticks enough, I hope some airline driver would do the same for me if I ever end up in a bad spot.
Cary wrote:.........Another issue of having a 406 that doesn't have 121.5 is that not all SAR groups have the capability yet of homing onto a 406 signal--they need the 121.5 signal. So it's IMHO it's important to have an ELT with both frequencies. ........
hotrod180 wrote:Cary wrote:.........Another issue of having a 406 that doesn't have 121.5 is that not all SAR groups have the capability yet of homing onto a 406 signal--they need the 121.5 signal. So it's IMHO it's important to have an ELT with both frequencies. ........
IMHO the whole 406 ELT thing is/was a solution in search of a problem. Since the search teams need it anyway, and the airliners monitor it as they overfly the country hither & yon, what would be wrong with the darn satellites just monitoring 121.5?
AK-HUNT wrote:EPIRBs/PLBs---All 406 - a decade now probably? The holdouts are in aviation…I don't get that part. After lives are lost every year and some make this very website…. Still?
I personally contribute it to the level of non-factual data on the internet (tho thats gotten better I suppose). Needing 121.5 is one of those.
AK-HUNT wrote:AEROPOD
I hope you have a 406. somebody returning that favor isnt much. Searchers search till the beacon quit - but without satellite listen they just aren't found reliable. 50/50 maybe. And even then it takes ALONG time. I wouldn't wanna be hanging in straps bleeding for 24 hrs. I just spend the $600.
Best part- every one of those not found 121.5s, the owner has no idea he's flying without anything then....till annual..(but had no idea how little help a 121.5 is to affecting rescue in the 1st place I guess)
There was my pitch-![]()
everyone buy a 406 pls. And register it. You owe it to the guys flying all night in the snowstorm to get u.
(sorry for the hijack - usually one of the AKRCC guys speak at the Ak Airman show. Get your facts there. Or callem. 24/7. Theres a lot more fiction than fact online)
NZMaule wrote:...do you have the 5/6th seat in and if so how is it affected by the lowering of the extended baggage floor panel?
NZMaule wrote:I have also been looking at the Steene strut cuffs, do you anticipate keeping the rubbers on the struts as well or are the the cuffs a replacement. I know the cuffs are cheaper than replacing the rubbers !!
NZMaule wrote:Firewall battery is great and can easily be jump started through the oil inspection panel if necessary.......been there and managed a start with the little antigravity battery MTV mentioned.
NZMaule wrote:It would be interesting to see what starter you get, keep in mind a continuation of the mods with a light propand get a starter compatible. Starter type, adapter type, power source and prop weight all need to be considered for trouble free starting issues.....unfortunately been there too.
roamak wrote:With Mikes comment above about the 121.5, thats the only way I found out my old kannad elt was full of water and corrosion. CAP picked it up while they where out doing touch and go's, landed, then tracked it to my plane. I would have never known my elt was junk until i either pushed the test button or sat on a gravel bar for days waiting for help that never showed.
Sounds like your going to have a nice ride!! Enjoy!
