What, pray tell, is wrong with a mod for the sake of doing a mod??????hotrod150 wrote:Also curious as to how you like them. Are they really an "upgrade" over the stock arrangement? I got a Monarch cap kit along with the airplane when I bought it. I'm planning on installing them, but want to make sure it's a useful mod and not just a mod for the sake of doing a mod.
Glidergeek wrote:They are functional, they are raised slightly above the top surface and have an umbrella type build to help keep rain or wash water out. Learning to fill and not make a mess topping off is doable the flap adds a challenge. Install is quite easy.
I mainly fuel out of cans (mogas), that flapper sounds like it might be a problem.
gear wrote:I know of three aircraft here in the Winnipeg area (where the Cap guy is located) where they've had issues of fuel siphoning out in mid flight. The gasket gets compressed and that's when the siphon starts. We were on a long flight a few years ago and we lost 15 gallons in the air. Landed with approx. 2 gallons. I call them killer caps, same as the original cessna ones. All of those guys ripped them out and put the second generation raised caps in. If you talk to the cap guy about this, he just tells you to flip the gasket around and it will be good to go. Kinda hard to do in mid flight and fuel is pissing out,....
Garth
