Flyhound wrote:
Ft Belvoir is deep in the heart of the SFRA surrounding the DC area. Getting in and out of the SFRA is a minor inconvenience. The best place to base your plane depends on where you'll actually live. If you're in Virginia, I'd suggest Stafford (KRMN) or Shannon (KEZF).
Amen to that Flyhound ! I live just barely outdide the SFRA perimeter, and Northern VA is horrible for flying and road travel. One thing about KRMN is the traffic out of Belvoir ( located roughly in Alexandria VA) onto Route 1 to get to Fredericksburg, VA. It is a mangle of solid metal. Whether you drive via Interstate 95 South or Rte 1 South either way you end up in a traffic mangle, unless it is say 2 AM.
One thing you might honestly consider is Frederick, Maryland (FDK) It is outside the SFRA, accessible via a series of toll roads ( Washington Beltway Express Toll Lanes to Dulles Toll Road to Dulles Greenway Toll Road and then north to Frederick, MD. In Northen, VA area travel time and traffic congestion are often more importangt factors than the actual distances. A friend has a PA28 there and in one of their “less deluxe” hangars he pays I think about 250-300 ? AOPA central office is right there at the field if that helps. Here is the SFRA:
As Flyhound said:
If you keep your 8.5s, there is a small, private grass strip right on the edge of the SFRA. VG-57 is owned by a fellow I met while back there and he has a special squawk code that let's him fly in and out without filing an SFRA flight plan.
If you can score on a hangar access on a private airfield say in nearby Loudoun, Fauquire or Prince William County, that might be the ticket.
Here are some pics of the joys which await you around Belvoir.
Compare that to the live traffic webcam for the Seward Highway here :
http://www.borealisbroadband.net/vid-searsmall1.htmGood luck with your move, and bring a batch of that Copper River Salmon with you
