My Water Flying issue came yesterday--great article by MTV on the dangers and how to address them of amphibs. Mike's discussion seems to boil down to doing a gear-position check at least 3 times in the pattern, and avoid being distracted by passengers or anything else during that period of time--the "sterile cockpit" rule. He mentions that a good way to enforce the "sterile cockpit" rule is simply turn off the passengers, as can be done with many modern audio panel intercoms. He also recommends using a standard rectangular pattern rather than an abbreviated pattern, as a means of defining where to do each gear check. These are all good pieces of advice for all of us, whether amphib or retract or fixed gear flyers.
I've never flown an amphib, and my overall float flying experience is pretty limited, but doing GUMPS x 3 served me well when I was flying retracts. So well, that although I haven't flown a retract in more than 15 years, I still do GUMPS x 3. I did it flying floats last summer, to remind me to check that the water rudders were up. I hope that if ever I have a chance to fly amphibs, GUMPS x 3 will work for me then.
