Barnstormer wrote:Had I decided to install the optional E-Mag Interactive Control And Display I would have the ability to adjust the maximum advance while in flight as well as get status reporting etc. I chose not to go that route due to the added cost and weight, with the only real benefit (as I saw it) of changing timing at other then full throttle operations.
Yeah that is what I was trying to figure out.
Are these mags adjusting the spark timing based upon the RPM and MAP, to increase efficiency in a clever way?
Or, are they simply providing a more powerful spark and claiming efficiency because you can pull the red knob back a little further than before?
I certainly like the idea. I have emailed the manufacturer to express my interest in buying a non-cert 6-cyl set.
) once I can keep the wheels on the ground.
