GumpAir wrote:mtv wrote:Again, if you go to interior and northern Alaska in the dead of winter, and look at the Cessnas on the ramps, you won't see many if any wearing those winter fronts, but you'll see a lot of duct tape on the oil coolers......![]()
Yup... No one I worked for had A&P's who allowed the winter fronts. We taped the oil coolers, climbed just a few feet into warmer air, and held power in the green until the wheels touched the ground. We were taught the colder it is, the slower you do everything.
Technique plays a huge part in keeping cylinders, and oil, warm. My rule was always be at pattern altitude at least ten miles out, and never pull back more than an inch every three minutes, stopping at the bottom of the green on the MP. All the gauges stay in the middle, right where they belong.
Some outfits did really shitty pilot training for winter ops, and I'd watch their guys come in on -40 days and be 3,000 AGL at three miles out. You could hear 'em cut power and stuff the nose down to come in and land. They replaced a jug a week. Us Chickenshits who kept our engines warm and at cruise power, ran engines from new in the crate to TBO without a squawk.
Using the winter fronts, and even more so taping off cowlings, is scary. You disrupt airflow over the cylinders, and even though the heads might show CHT's where you want them, you run the risk of hot spots on the cylinder walls.
can't let any of these beauties disappear....
mtv wrote:And, bear in mind that, while the oil temp at the sensor may be 180, SOMEwhere in that engine, that oil is in fact in excess of the boiling point. As that water vaporizes there, it passes through the engine and is evacuated through the crankcase vent.
At the Lycoming Piston Engine Service School, they emphasized the notion that if you get the indicated operating temp to 180 and keep it there for a while, you'll cook off most of the moisture in the oil, and your engine will last a lot longer.
So, the magic number is 180 f.
It's also a good idea to calibrate you oil temp probe, to verify the accuracy of the instrument...I found one once that was waaaay off, on the low side.
Grasstrip....yes, the 20 degree F admonition was what I recalled. In Fairbanks in mid winter, we couldn't run them, because at any decent altitude the CHTs would rise alarmingly. Once you're airborne, and find that inversion, it's hard to remove those things....![]()
