Backcountry Pilot • Old Stickers Off?
Old Stickers Off?
11 posts • Page 1 of 1
Old Stickers Off?
Hey Guy's - Do any of you know how to get old stickers off an airplane? Before I started trying heat, chemicals, razor blades (I did try my fingernails and that doesn't work), I thought I would ask here.
Thanks in advance for your advice!
Jim
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
Re: Old Stickers Off?
Try a Hair dryer. That should help them peel right off. Its safer on the paint than a heat gun. I have only used this trick on stickers that are 3 months old, older stickers might be harder.
good luck.
Waterboy offline
You might check with your local windshield shop (for cars). The one I use has some sort of spray-on chemical which allows them to remove inspection stickers from the old windshield and reapply them to the new one.
Body shop supply places have a rubber wheel that goes in a drill, some go in a dye grinder but the drill ones work better and last longer in my experience, it is kinda like a big eraser it works awesome and won't hurt the paint.
You will never remove stickers by hand again, trust me!
Worth makes the best ones not sure if they are in the US though.
River rat offline
"Goof Off". You can get it at any hardware store. I wouldn't use it on a fabric airplane. On a metal aircraft I would test it on a small area first. The stickers and adhesive will come right off.
Bender offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... QWUi6dqfEQ
Aircraft: PA-22/20
just get a bigger sticker that you like and cover it up?
Jim,
Head down to a paint supply house and get a stripe eraser. Put it in your cordless and it will peel them off in a hurry. Be careful and take your time. On one occasion I had it get into the paint a bit, but it was poorly applied paint, so I blame that more that the tool.
TL
AEROPOD offline
patrol guy wrote:just get a bigger sticker that you like and cover it up?
My thoughts precisely! :D
A hairdryer and fingernails did the trick... The new ones are on order...
jaudette offline
Vans RV-7a
Pictures when they get on, please!
CamTom12 wrote:Pictures when they get on, please!
Will do - I'll put them on my Bo Beautification page!
jaudette offline
Vans RV-7a
