Ah, the infamous full flap go around. For Motoadve, it's important to understand the big difference between the later 182 and the 180/185: The trimmable stabilizer on the latter....a VERY powerful trim system.
But, so far at least, nobody seems to have found the "silver bullet" to deal with a full flap go around, so I'll offer the technique I figured out many moons ago:
First of all, it's important to understand why there is so much forward force required on a full flap go around. Again, it's that really powerful trim system.....and frankly, most of us are landing these things with a fairly far forward C of G. Which means to achieve a "Trimmed condition" on short final, with power back fairly far, you'll have a LOT of nose up trim rolled in to counter that C of G and the flap effects, etc. Now, you execute a go around, and YIKES!!! Most folks (except the Terminator) are going to be using both hands on the yoke, pushing like hell to keep the plane from pitching up and stalling.....not a great scenario. Turn loose with one hand to reduce power or roll in some nose down trim???? Sure, if your left arm is stronger than mine.....go for it. But, I don't like reduced power go arounds....mind you they can be just fine in certain circumstances, but what if there are trees out there, in the top of the windscreen?
So, here's my technique: On approach, with full flaps and power back a ways, I keep some nose down trim on the plane. Which means that I have to hold back pressure on the yoke....not huge amounts, but noticeable.
So, if I have to execute a go around, I push up full power, and because the trim is essentially set for level flight, I really don't have to do anything except push just a bit on the yoke. As the airplane reverses the downward movement, and actually levels in preparation for climb, I easily reach for the flap handle, and come back to 30, then 20 degrees of flap.
Simple solution. But, wait, there's more:
Many of us (except those super pilots out there) mere mortals have to work pretty hard to time the push on the yoke during a wheel landing in one of these airplanes. Why? That spring gear has a lot of spring to it, and just a tiny bit of downward vector at the touch is going to launch you back into the air.
So, back to the full flap approach technique: Some nose down trim, and thus, you're holding just a bit of back pressure (nose up) on the yoke. As you approach the surface, you flare to ALMOST the three point attitude, and hold it. Tail just a few inches off the surface. Which means you're holding just a bit MORE back pressure on the yoke.
There are two bits of good news here:
First, that tail low, almost three point attitude is going to get the airplane just about as slow as it's capable of landing.....as opposed to what a lot of folks call wheel landings, with the tail high, just rolling it on, whilst whistling along at 70.......Yow!! And, when it comes to landing, slower is good, in a whole bunch of ways, not the least of which the airplane is pretty much in a very low energy state, and therefore it is much less likely to bounce, and if it does, it will settle right back on.
Second, human nature suggests that what we all really want to do after a landing is to relax......tailwheel pilots know better than to try that one till the airplane is stopped......BUT: In the scenario I've described, the airplane is tail low, very low energy, thus less likely to bounce, and you're holding back pressure.....what you now want to do is to get the tail up, and thus "stick" the landing. And, all you have to do to initiate that process is to RELAX that back pressure.....and a half second or so later, apply some forward pressure to the yoke. And the airplane is on, the main wheels are stuck, the plane is pretty much done flying and bleeding energy rapidly, so now you stab and steer.
The beauty of this approach and landing is that it makes wheel landings very easy to pull off, because the timing of the push and the rate of descent at the touch are less critical.
Give this a try sometime, I think you'll like it.
As to big crosswinds, it depends on the surface, but on anything but pavement in a big and gusty crosswind, I'll be a full flaps, and three point the plane, stick it hard, and steer it, with ailerons full into the wind, and standing on the brakes.......It ain't pretty, but it gets er done.
