Karmutzen wrote:....hotrod180. You have a Garmin 296 on the panel. Run a wire from the NMEA output on its power/data harness (violet wire, page 134 of the manual) to the NMEA input wire of the G5, I think it is green. Then all the nav information on the 296 will display on the G5. Now if you then go for the FC-10 fuel flow, connect the same NMEA output from the 296 to the NMEA (serial) input on the FC-10, and it will then reference to your waypoint in the 296: fuel to get there, fuel remaining after you get there, how many nm per gallon you are burning.
JP256 wrote:For what it's worth, the new "Guardian" series of panel mounts seem quite nice, and have now received FAA approval (under the NORSEE policy) for installation in certified airplanes. Here's their press release: https://www.guardianavionics.com/Guardi ... t_b_6.html.
I wonder why AirGizmo hasn't gone through the same approval process?
Users browsing this forum: No registered users and 59 guests
