Mapleflt wrote:I see a line of Champion generator but not Companion ?
denalipilot wrote:Mapleflt wrote:I see a line of Champion generator but not Companion ?
Sorry for the confusion- those are also Honda models: Honda EU2200iS and Honda EU2200iS Companion. i.e., the Companion version is designed to run in parallel with the basic Honda EU2200iS.
They may not be up to the demands of your house/ shop, but the upside is the versatility of having two 2Ks, or linking them to have the functionality of a 4K when desired. And they are easily picked up and carried around. Probably more of a back-up solution for a home/shop, than a regular supply source, especially due to the lack of 240V output.
skyward II wrote:Predator 3500 watt gets it done cheaply. Honda 3000 is best but not cheap. Keep the fuel clean. Gummed up carbs no fun…
Mapleflt wrote:I've been told by others that can be an issue, would it be advisable to use a specific blend of Dino Juice, ethanol free etc. A couple of people have suggested TruFuel for the smaller, more finicky engines.
Ross4289 wrote:300 pounds? My 5,000 Predator only weighs like 120 and I flew it in.
