PAMR MX wrote:I rarely see one on a Cessna. I wonder about the crashworthiness of the glass bowl deal? Have you ever seen the glass bowl Cessna filter assembly with the glass replaced with an aluminum bowl?
The late model Cessna's from about 1965 and on have to use an adapter bracket in order to use my Gascolator... All the earlier glass bowl ones are direct replacement... I have seen aluminum replacement for the glass, however you still have to deal with the bail system and two flat gaskets for seals..
Yesterday was a scheduled annual on a Cherokee so no work was done on the 182... Here is today's progress...
This is a better picture of the issue I had with the air box... The flapper arm should be centered below the inlet to the carburetor..
Installed new baffle seal material...
Sean posing with his toy.. [emoji3]
Left side front of the engine... Removed the oil galley plug and installed my fittings to hook up my pre-oiler pump...
Pre-oiler pump... Older than dirt... This thing has done a hundred or so aircraft engines, some flat head Fords.. Couple of small block Fords and one Chevy...
I put in three quarts with this pump... New drill motor because my old one bit it a while back...
https://vimeo.com/147913192And the moment of truth... Oil pressure was immediate.. Mags checked out good... Did not get enough RPM to cycle the prop... No oil leaks after... As you can tell in the video it was too late to do the break in flight, so will cowl it up and weather permitting fly her on Saturday..
Brian
