I just got our engine back from Aero Engines for the Pponk conversion and installed it. We're seeing a very large vibration from idle to 1750 RPM during ground runs. It feels like it's around 5 Hz at idle and is large enough that looking at the instrument panel will make you sick and is unairworthy. We adjusted the idle mixture both rich and lean, and ran the mixture control at all speeds trying to smooth it out with no success. Since it smooths out at 1750, the issue seems to be an idle circuit issue. We are running our original C66 prop that ran smooth prior to the overhaul, does not have balance weights, and is clocked as it was before. Lycon performed the carb modification and bench flowed it. Aero Engines performed a test cell run with this carb down at sea level prior to shipping to us here in Colorado at 5050' elevation.
We checked for leaks on the intake system and found nothing. Mag drops are equal at about 80 RPM. It doesn't feel like a dead cylinder but we can't be certain as we have only a single point EGT and cylinder temp. We checked all the mounts. I did buy a new Knisely exhaust.
Anyone have a similar issue with their Pponk conversion? The engine shop has a loaner carb that we are on the wait list for. Sounds like this must be common if they have a loaner carb....
Thanks!
