Backcountry Pilot • Quick Jack Option
Quick Jack Option
40 posts • Page 2 of 2 • 1, 2
Re: Quick Jack Option
hotrod180 wrote:
Rob wrote:...Another difference was the use of L19 rings (I picked up from user 'aqua') as a the attachment point instead of axle insert. This makes the 180 towable with the same tow bar as the work planes.....
I bought a set of L19 tow lugs with the idea of installing them for use as as jack points,
they were plenty stout enough for towing but they seemed a bit scrawny for jacking.
Not sure if they'd hang in there holding the weight of the airplane without bending.
I never installed the tow lugs I bought, but here's a photo of a set on another C180.
I measured mine-- they're approx. 2-1/8" wide & about .167" thick.
They're plenty stout enough for towing purposes,
but considering the size of the hole in them, and probable jack placement,
there's not a whole lot of material where the bending moment would happen when used for jacking.
So I decided to stick with the hoisting method.
Not sure how the tow rig hooks in, but a gusset might work to help make those a viable jack point.
I still think hoisting is a better, more stable method though.
CamTom12 wrote: Not sure how the tow rig hooks in, but a gusset might work to help make those a viable jack point.
I had the same thought as you re adding gusset(s),
THEN had the same thought as you re hoisting being better anyway.
So the tow lugs are still on the shelf for now.
But someday they might figure into a different way of strapping to the hoist,
to avoid having to use a possibly paint-marring choker.
The parts arrived from the machine shop today. They look great! Boxed and shipped the first 5 sets tonight. Unfortunately I'll be leaving for a biz trip shortly and won't get to install/try out until I get back later in February. I'll keep the thread posted with results.
hamer offline
I had a 2 week business trip and wasn’t able to install the parts until this weekend. Everything works great! The motorcycle stand could use a little longer lever arm to get it over and up on the stand, but that’s an easy fix. It does jack it up way higher than I actually need, but I guess that gives me some growing room if I end up with bigger tires.
I have 5 more sets of the plates if anyone else wants a set.
hamer offline
Did you have to use longer axel attachment hardware to compensate for the plate?
Hammer offline
Hammer wrote:Did you have to use longer axel attachment hardware to compensate for the plate?
I was using 3 washers before, with the plate I got away with a C4 washer under the head and a standard washer under the nut, with 3-4 threads showing. The bolts are MS20004-28.
hamer offline
I think I'm going to try these wheels out from pro eagle. They make pretty aggressive off road racing jacks.
BIG WHEEL JACK FRONT WHEELS 6" | Pro Eagle
hamer offline
Do still have a set available....what would the cost be shipped to Texas....looks like a good CV project....
Airdave100 offline
Aircraft: 1956 Cessna 182....N5632B
Anyone else get a chance to install/use these yet? I repacked my wheel bearings the other day, came in very handy!
hamer offline
I'm interested! Did you have to make a pin for the pitbull stand or did you use one of their off the shelf ones?
62150B offline
Aircraft: 1962 150/160
62150B wrote:I'm interested! Did you have to make a pin for the pitbull stand or did you use one of their off the shelf ones?
It's one of their off the shelf ones, it is this one:
https://www.pit-bull.com/motorcycle-app ... -f0099-015
hamer offline
Do you have any of these plates available? Will it fit my 182B? What is the cost? Thanks Dick
flyer offline
Aircraft: Cessna 182B
flyer wrote:Do you have any of these plates available? Will it fit my 182B? What is the cost? Thanks Dick
I think I have two or three sets left. This isn't a for sale thread so I'm trying to not get salesy here, PM me if you decide you want a pair, I'm selling at my cost + shipping. Making multiple sets brought my cost down so I'm passing it along.
This is the bolt pattern, except with 1/4" holes. You can drill them out to the correct size if your axles match.
hamer offline
Where can I find a tow bar like that? I have some lugs, but interestingly they bolt to all four main gear bolts, rather than just two bolts like the stock lugs in the photo appear to.
atypicalguy offline
Aircraft: c140, c185
I haven't been on this site for a few years, but I've had a flood of people asking me to buy these.
The prices have gone way up since the first time I made these in 2020. If I get 10 interested people I should be able to get the price down to ~$200/set.
Let me know if you're interested. If I get 5 people willing to pre-order/pay, I'll order the 10 sets and sell the other 5 as orders come in.
Shoot me a PM if interested.
hamer offline
I use tow lugs on my 180, I just built a tow bar out of 1” tube.
I cut a piece of 2x6 with a 40 degree bevel on each end that fits perfect between the axles, then use a floor jack as tight to one side as I can get it to jack up a tire.
The tow lugs are a Cessna part, from a bird dog.
StillLearning offline
I carry an old Ford screw jack, they are very small, don't weigh much and can lift plenty high enough. Most planes will need some sort of a bracket on the gear leg or a jacking point as the OP shows.
shorton offline
Aircraft: Stinson 108-2
For the 185 I have a 3000# (small) automotive scissor jack that I welded a cup onto the lifting pad at a 90' angle. The cup slides right under the gear leg and into the wheel/brake gap. I bonded a 1/8" rubber pad to the cup so it won't slide around. Lifts the gear leg just fine. When testing I lift the gear leg off the ground, lower it and reposition the jack for a second lift as the gear leg moves outboard when lifting. Never had to use it because its always onboard!
dar636 offline
Aircraft: Cessna A185F (sold)
Cessna P206E
dar636 wrote:For the 185 I have a 3000# (small) automotive scissor jack that I welded a cup onto the lifting pad at a 90' angle. The cup slides right under the gear leg and into the wheel/brake gap. I bonded a 1/8" rubber pad to the cup so it won't slide around. Lifts the gear leg just fine. When testing I lift the gear leg off the ground, lower it and reposition the jack for a second lift as the gear leg moves outboard when lifting. Never had to use it because its always onboard!
Sounds pretty slick.
Can you post a photo?
