Jeredp wrote:whee wrote:I always enjoy engine work posts. Looks great, I'm not a fan of Continental gold either.
Question; When work like this is done are components dimensionally checked? I.e. Measuring the cylinder bores, pistons, crank journals, etc? Or do you just visually look stuff over and put it back together?
I measuered almost everything in the bottom end. I didn't disassemble anything in the cylinders, so bores were not measured.
Jared, nice work! Looks awesome and I am sure it is nice to not have to worry about leaks. Thanks for posting this!
FYI- I fixed your pictures that were rotated 90 degrees.
When you copied and pasted the links they looked like this:
backcountrypilot.org/images/
originalphotos/3386/5307/bec088e7f371f7097cade705.jpg
The trick is to just remove the "original" out of the link. Like this:
Typically it is easier to just take it out of all the pics rather than try and find the specific ones that need fixed. Hope that helps.
