Backcountry Pilot • Rear intercom wiring
9 postsPage 1 of 1
Have a Sigtronics 4 place sgi stereo intercom to replace my old sigtronics 2 place in my 182. Planning on starting the work in the next little while. I need wire for the rear jacks. 20 awg 3 conductor twisted shielded ground seems the best, but who sells it? Nothing at spruce...Other options?
Mark Y. offline
Aircraft: Cessna 182B
Re: Rear intercom wiring
20ga is probably more wire than you need. 22ga should be sufficient and is readily available.
~Chris
Chris In Marshfield offline
Aircraft: Vans RV-6
Quicksilver Sprint II
Warner Spacewalker II
There's always Radio Shack, too.
I would use 22/3 Mark.
Perfect the 22 popped right up on spruce's site. Not sure why they only supply a 4 ft length for the rear seats with the kit, wire is relatively cheap.
Mark Y. offline
FWIW, until I had my PS Engineering audio panel installed 4 years ago, which includes their outstanding intercom, I had a 4 place Sigtronics for about 9 years. It worked OK, but by its design, it opened all 4 mics whenever one was triggered--it only had one channel. It also tended to clip speech, not breaking squelch immediately and squelching if the speaker lowered his/her voice a little. It seemed like I was always having to fiddle with the squelch. So there may come a time when you'll want to upgrade to a better intercom; if you do, I can definitely recommend PS Engineering. Meanwhile, I suggest that not plugging in the headsets that aren't being used helps a whole bunch to minimize annoying false triggering of the intercom.
Cary wrote:FWIW, until I had my PS Engineering audio panel installed 4 years ago, which includes their outstanding intercom, I had a 4 place Sigtronics for about 9 years. It worked OK, but by its design, it opened all 4 mics whenever one was triggered--it only had one channel. It also tended to clip speech, not breaking squelch immediately and squelching if the speaker lowered his/her voice a little. It seemed like I was always having to fiddle with the squelch. So there may come a time when you'll want to upgrade to a better intercom; if you do, I can definitely recommend PS Engineering. Meanwhile, I suggest that not plugging in the headsets that aren't being used helps a whole bunch to minimize annoying false triggering of the intercom.
Curious what model you had? I've worked on many sigtronics and had a couple now and have never heard of that. They work great and I really like the sigtronics.
Mark, not sure which one you got, but the 4S has a seperate volume on its case as well as the front. Be sure to try it and make sure it's high enough before mounting it in the panel. It's a can he a bit of a pain to adjust after, depending on where you mount it.
David
I got the new SCI -4 as a present last Christmas. I sure hope it would be decent. The 80's era one I have still works ok, just only two place.
Mark Y. offline
David
I haven't any idea what model it was. It was installed in the airplane when I bought it, and only wired to jacks for the front seats. At the first annual after purchase, I asked my IA about getting a 4 place model, and he told me that what I had was a 4 place, only wired for 2 places. So he added some jacks for the back seat. As I said, it seemed to work fine; the PS Engineering intercom is just a whole lot better.
9 postsPage 1 of 1
