Fri Sep 15, 2017 10:56 am
I had a bunch of adhesive to remove the other day on the large panels of the Caravan before I re-covered them. I found the Goo Be Gone Citrus based solvent worked like a charm and didn't require the use of a respirator. If you spray it on and then cover the area with plastic wrap and let it sit for a bit, 10-15 minutes, you can scrape it off with a plastic putty knife. It would even soften the really hard adamantine grade glue.
MEK is really, really, really bad for you if you get it on your skin or inhale it. While it is an excellent solvent and cleaner you really need a quality respirator & gloves to work with it. While replacing the headliner, I was using a special glue, made for headliners. It had in big letters; specially formulated for aviation. Then in slightly smaller letters, it warned, "Do not use in confined spaces." Wait, aviation glue, you do not use in confined spaces! Well, I would have to do a part, tack it down, retreat, let the aircraft air out. Repeat the process. Stuff smelled like burning alien mummies.
