removing cessna hatshelf?
- baggage.jpg (26.61 KiB) Viewed 2774 times
On my 170b I am putting a new headliner in, I have the extended baggage and this piece of trim is really annoying and gets in the way of bulkier items. Can it be removed, or some tinnermans sub'd for the rivets? Baggage shelf I believe p/n 0512148
alaskan9974 offline
96
I can promise you you'll never miss it.
2793
- Aircraft: C-170B+
98.99%
of people remove it when they do the extended baggage
corefile offline
637
- Aircraft: Cessna 180 - sold
Wed Jun 09, 2021 10:00 pm
I had the same question when I installed my extended baggage. What’s the basis of eligibility for its removal? I don’t remember specifically, but I think that it is not illustrated in any of the Selkirk instructions, so I deduced that it’s removal was part of the install instruction for the STC. They really are not perfectly detailed so you have to fill in the gaps in the steps that are described. Removal of that piece is one of those gaps. Not as definitive as you’d like, but the best that can be done.
Pinecone offline
996
- Aircraft: Cessna A185F
Wed Jun 09, 2021 10:24 pm
Pinecone wrote:I had the same question when I installed my extended baggage. What’s the basis of eligibility for its removal? I don’t remember specifically, but I think that it is not illustrated in any of the Selkirk instructions, so I deduced that it’s removal was part of the install instruction for the STC. They really are not perfectly detailed so you have to fill in the gaps in the steps that are described. Removal of that piece is one of those gaps. Not as definitive as you’d like, but the best that can be done.
Works for me....thanks
alaskan9974 offline
96
Wed Jun 09, 2021 11:35 pm
Airglas extended baggage has no basis for removal.
Minor thing to remove IMO.
Aryana offline
936
- Aircraft: 1955 Cessna 170
I agree with Aryana’s approach as an alternative. It is really only an upholstery attachment clip. I just didn’t mention the removal in my log entry based on the assertion that it’s removal was implied in the Selkirk instructions.
Pinecone offline
996
Pinecone wrote:I agree with Aryana’s approach as an alternative. It is really only an upholstery attachment clip. I just didn’t mention the removal in my log entry based on the assertion that it’s removal was implied in the Selkirk instructions.
Love it "removal implied"
Goes with my favourite "as found on aircraft".
1303
Thu Jun 10, 2021 10:09 am
I would sincerely hope that your mechanic would happily make a log entry that this non structural piece was removed during installation of the extended baggage.
The baggage has to be signed off. Surely removal of that "Hat shelf" (and yes, that's what it was) is a "minor alteration" at worst.....
10588
Thu Jun 10, 2021 10:45 am
I didn't remove my hat shelf due to the rear seat back attachment. What are you guys doing if you want to still use the bench seat?
Mark Y. offline
443
- Aircraft: Cessna 182B
Mark Y. wrote:I didn't remove my hat shelf due to the rear seat back attachment. What are you guys doing if you want to still use the bench seat?
They where two separate pieces in my 1952 170B, when did they become one ?
2387
MTV, the way it goes with my Aircraft Maintenance Engineer is that I typically write the log entry after he coaches me. Then he reviews, edits, and coaches me some more. No wool is ever pulled over his eyes. I’ve worked too long and hard to earn his trust. The definition of minor vs. Major mod is a bit tighter here than under FAA rules. Some FAA approved STCs, particularly the older ones, would not pass current criteria with their documentation. We deal with it the best we can. Not looking to taunt Transport Canada into a debate. We try to make it easy on ourselves and on any official who may have to audit us.
Pinecone offline
996
Mapleflt wrote:Mark Y. wrote:I didn't remove my hat shelf due to the rear seat back attachment. What are you guys doing if you want to still use the bench seat?
They are riveted to the bottom of the shelf on my 59 182B
Mark Y. offline
443
That would make the shelf a major airframe member as "load bearing" structure so no longer a minor modification.
2387
Mapleflt wrote:That would make the shelf a major airframe member as "load bearing" structure so no longer a minor modification.
I agree. Would have to install atlee dodge or lakevue seats to get rid of it.
Mark Y. offline
443
Not sure where the back seat bolts on, I have folding jump seats installed. Might’ve thrown old back seat away, can’t find it.
alaskan9974 offline
96
Mark Y. wrote:They are riveted to the bottom of the shelf on my 59 182B
For OP, this doesn't apply to his 170B hat shelf.
Aryana offline
936
