Has anyone ever replaced a main gear leg on a 182A that was sagging? I noticed when I bought my plane this year that the left wingtip sat about 4-5 inches closer to the ground than the right side. When viewing the plane head-on sitting on a flat surface it appears that the left main does not have quite the “crown” that the right side has. I’ve examined the fuselage closely for deformation and looked inside the gearbox for anything that might look damaged or deformed. All looks fine. I found a pair of gear legs the other day on a ‘58 in a salvage yard that looked good for a very reasonable price. I’m gonna buy them both. I was told to buy both as they were made in pairs. I have no idea if that's true. Anyway, I want to get them home and strip and paint them. I read not to use a power sander on them as the heat build-up can harm the shot-peering and consequently the temper in them. With regard to striping them, not to use a highly acid stripper as that can harm the temper also. Geez, is there anything that won’t “hurt” an airplane. I was planning on repainting my original gear anyway.
So, any ideas on a gear swap? The guy with the gear says they are no big deal to pull out and replace. He said he has a way to lift the airplane for that but I’m gonna do some research first.
And the stripping? For paint I was planning on just using SEM self etching primer and the white paint I had made up to touch up the plane. It’s a 3-part system with a reducer (for spraying I think) and some sort of catalyst.
Any ideas with experience attached are much appreciated!
