8GCBC wrote:.......I use 8.5 on pavement but would not mind operating on a smaller less expensive tire. I called the factory and they advised not to go any smaller than 8.5, because it was not approved..............
hotrod150 wrote:8GCBC wrote:.......I use 8.5 on pavement but would not mind operating on a smaller less expensive tire. I called the factory and they advised not to go any smaller than 8.5, because it was not approved..............
This is sure opposite the normal trend on this site!
I found it interesting that 850's are the only MLG tires approved for your airplane.Just out of curiosity, I looked up the TCDS for the 8GCBC. It's got the newer format, ike the TCDS for my 1964 Cessna, which I don't much care for-- lists engines & props, and CG information, but nothing about much of anything else. The older format TCDS listed approved options for basically everythng on the airplane that could be removed, such as tires, including weight and station (arm) for W&B purposes.
