8GCBC wrote:My 00.02 USD ramblings....
Local knowledge is paramount.
Reading "Nature" takes time and experience.
I spent several years driving/flying on beaches and rivers in Australia. 8.5 is not an ideal off-airport tire. It may work in many areas but, I would simply get bigger if I could. Riverbeds are (can) be dangerous for any vehicle. Don't let anyone convince you otherwise.
With local knowledge 8.5s can hold a loaded (over gross) C180 on a beach with solid sand (barley leaving tire tracks). But possibly, a mile down the beach it would sink and die.
I repeat (at the risk of beling offensive...)
Reading "Nature" takes time and experience. Get as much information as humanly possible before each flight. If there is a known safety void do not go!
Carry on men...
glacier wrote:There is still a strong sense of adventure alive here. But nobody likes seeing a plane on its nose either.
Sand can vary from hard enough to roller skate on to soft enough to bury almost anything short of a light cub on 35's. The two ends of this spectrum can be present in the same vicinity on a beach or a bar. The advice given here also spans this spectrum, and is just really hard to give, let alone to give over the internet.
Battson wrote:glacier wrote:There is still a strong sense of adventure alive here. But nobody likes seeing a plane on its nose either.
Good post - my sentiments exactly.
Also, yes - all the old guys down here used to do EVERYTHING in the backcountry on on 8.50s, but only because they were the largest tires readily available at the time. It doesn't mean it was the best way of getting it done, it was riskier. Its just the way things used to be.
Its analogous to building the Hoover dam or the Empire State building. Taking high risk and occasional loss of life used to be accepted. These days, not so much.
To the OP - I would say avoid SAND bars where you can, and stick with gravel and rock - particularly the high and dry stuff. You'll do fine there, better to accept a few rocks in the tailplane than to stand the plane on its nose. Sand is the nasty part of the whole equation, a gravel bar is a lot easier to read a more forgiving.
cstolaircraft wrote:ok maybe this will make it easier. A buddy has a Just SS with 29's, he lands all over the place. I plan to follow him the first few times. What kind of tracks from him should i be looking for to know if it will handle my 8.50s? I have landed the SS on the sand bars and made noticeable tracks but they didn't appear to have any real depth to them were the mains hit the tailwheel did make a larger mark.
JS170B wrote:8.50s on sandbars? No way. 29s have excellent float on sand. 26" Goodyears are doable but not ideal on soft sand, much less float than the 29s. Landing soft sand on 8.50s and you may expect to leave the plane there.
Jim
Sidewinder wrote:There is one pretty sure fire way to land on a potentially iffy surface, if need be, otherwise if it looks questionable and you don't need to, do don't do it.
I use a similar technique for snow and Ice, except when it comes to soft ground, instead of using a wet log, I use a rock the size of a cantaloupe.
Determine the point where you want to be stopped at, and drop the rock, if the surface is soft or marginally hard crusted the rock will carry enough energy to punch through it. If it looks good use your finely honed skills to make your approach so you will be stopped over the rock.
The rolling drag method is unpredictable and I would not risk a 60k+ machine on it. It is surprising how slow you can roll over a shit surface and not make any significant impression. If you can stop on a confirmed solid surface, for the most part the surrounding area is of little consequence with reasonably sized tires. If you don't get out for some reason to determine the integrity of the departure run out, then use an expedited take off procedure, once your up to some rolling speed you should be safe.
This is where flour bombing and pumpkin dropping practice can come to practical use.
