There was mention of the Stratux in this thread a while back: https://www.backcountrypilot.org/forum/new-adsb-product-18707?p=259598#p259598
The build itself only took a few minutes, then I spent a couple hours researching the various EFB apps that are free for Android. The parts necessary are outlined on cyoung's website (http://stratux.me/) and only cost ~$130 for a dual band setup with an external mount GPS. The parts are as follows, and all available on Amazon:
Raspberry Pi 3 motherboard
Pre-programmed SD card with Stratux software
Stratux 1090ES & UAT (radios and high gain antennas)
Stratux clear acrylic case with small CPU fan
Vk-162 remote mount GPS (optional but gives a stronger signal)
cyoung also recommends a portable battery to power the system. Right now I'm using a small rechargeable battery (2600 mAh) for cell phones, but will probably ditch our panel mounted Garmin Aera 510 which should free up a power source for the Stratux.
Here we have the acrylic case with the fan installed next to the Pi, the two "nano" SDRs (which connect to the antennas), and a couple heat sinks that are included to stick onto the Pi
Here are the SDRs and heat sinks are installed on the Pi
Everything installed that goes in the acrylic case, the tan cords with red end caps are the MCX-SMA pigtails that connect the antennas to the SDRs
And now all closed up with the 978 MHz and 1090 MHz antennas, the external GPS antenna (black cord/unit), and my small portable battery (white cord/silver rectangle)
The initial boot up took a few minutes then it connected easily over WiFi with Foreflight on my dad's iPhone 6. Connecting on my Galaxy S6 took just a bit more work, as I had to install the Avare external I/O plugin. This defaults to port 43211 but it needed port 4000 to listen to the data (only click save if you want to record and save the full .bin file, which isn't really necessary unless debugging). Now I could see all the data that that the Pi was transmitting over WiFi and the Avare app showed lots of traffic heading in/out of the Denver class B! Didn't pick up any WX on the ground though.
Fast forward to my short flight around the patch and I had full ADS-B In WX and traffic in a '57 Pacer! Nothing beats keeping your eyes out the windows for traffic avoidance but this is pretty cool
