ExperimentalAviator wrote:So EZ,
At 6 feet and just under 250lbs would it be worth it to even think about a BC12 at all?
Think... yes. But absolutely try one on first, because it will be tight, and the test result may come back as a "no".
Like I said Forrest Barber is fairly big, and he's flown these airplanes for 50 years. To be brutally honest I haven't missed many meals in my life (although I'm only 5' 8" or so), and I've owned four of the Taylorcrafts without any significant problems. But I flew them solo 90% of the time.
There is an existing STC to add a skylight, I think it's called the "Clayton" STC from somewhere near Anchorage. This STC is best done during a fabric recover, since it involved welding new tabs all around the top of the fuselage. This essentially creates the equivalent of the later factory F-21 series skylight.
Because I had a T-craft with really good fabric, I developed a DER/DAR approved Field Approval for a no-weld STC, using the existing wood upper side fairings, a new wooden fairing at the rear spar, and a new wood support with Adel clamp attachments at the front. This does not require full re-covering or welding. But to be honest it takes more time to install than it would to weld in the tabs with the Clayton STC. I did it this way only because I'm not a welder.
Regardless of which skylight you use, the skylight gives you another 2 or 3 inches of headroom versus a stock headliner, and also delivers a tremendous improvement in visibility.
The Taylorcraft seat can be adjusted, you remove the five or six small bolts holding the seat sling to the front seat frame cross tube, then you "un-roll" the seat sling wrapped around the wood anchor strip, and re-attach it. This lowers the seat a couple of inches.
There is another STC to move the rear seatback cross-bar rearward a few inches,a nd another option for making the bar temporarily removable for loading baggage.. This is a weld job that also needs to be done during a rebuild.
If you're 6 feet tall then some or all of these modifications will make the T-craft fit you better. But if you are really tall the B model Taylorcraft is probably not for you, and you need to look at the F-22 which has seat rails.
