The Glazed Look
Sat Aug 23, 2025 10:38 am
What would be the most likely leading cause for a glazed cylinder wall, would an overheating condition present in such a manner ?
2329
Low cylinder pressures during initial break-in period of a newly honed cylinder and new rings. According to Continental if you don't run it hard enough to break in and seat the rings, the cylinder walls will glaze and the only fix is to remove and re-hone and install new rings.
1975
- Aircraft: 1955 Cessna 180
Sun Aug 24, 2025 11:36 am
soyAnarchisto wrote:Low cylinder pressures during initial break-in period of a newly honed cylinder and new rings. According to Continental if you don't run it hard enough to break in and seat the rings, the cylinder walls will glaze and the only fix is to remove and re-hone and install new rings.
This. High pressure is needed to “force” the rings into cylinder wall for good score.
Additionally, oil additives may also contribute to glazing. Shell 100 even if you are replacing just 1 cylinder.
skyward II offline
447
skyward II wrote:soyAnarchisto wrote:Low cylinder pressures during initial break-in period of a newly honed cylinder and new rings. According to Continental if you don't run it hard enough to break in and seat the rings, the cylinder walls will glaze and the only fix is to remove and re-hone and install new rings.
x3. Make sure you are using mineral oil for the entire break in. Even if its just one cylinder.
5192
